| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
Troubleshooting 3.4 Swaps
#2 (permalink) |
Symptoms:
Hard to start, bogging at first of quick throttle action while at a stop, bogging if more than a feathering of throttle was applied while under load, Backfire. Solution: I forgot to hook up the power wire going to my sensors. |
#3 (permalink) |
Great idea.
Symptom: battery not charging. Solution: my 3.4 wiring harness did not charge the battery. Had to graft the 3.4 alternator plug onto the 3.0 harness that I didn't remove (thankfully).
__________________
1991 4Runner, 3.4 5VZFE swap, OME shocks/springs, 33" BFG All Terrain T/A KOs, Pioneer head unit, Infinity speakers, XM Satellite radio |
#4 (permalink) |
Symptom: Couldn't get codes from ECU, Code reader just said error.
Solution: I had my STA wire jumped with a constant 12v which made the ECU think I was trying to start it when I would turn on the key.
__________________
92 4Runner 3.4 Swaped |
#5 (permalink) |
i have had no problems... so far... 3.4 since feb.
__________________
92 toyota truck 3.4 5spd 4.56 gears magna flow cat and muffler2 1/4 piping isr mod to intake 1.5 bjsfront add a leafs and 2inch lift shackles rear rancho shocks all around sitting on 265/75/r16 nitto terra grapplers |
#6 (permalink) |
Symptom:
While driving there was no power at all, Slight bogging at idle rev. Solution: I unplugged my spliced plug going to the ECU and it ran great, which told me it was wiring. I had my STA wire to the ECU supplied with a constant 12v, instead of 12v just while the key was in the start position.
__________________
#7 (permalink) |
Symptom:
Pulling a "Temp circuit error" code. Solution: I had spliced into the temp wire for the ECU instead of the temp wire in the body harness plug.
__________________
#8 (permalink) |
after my last swap, I kept getting a po125 code. when I did the swap, I put a new cat and o2 sensors. ended up that the brown ground wire was broken at the pin inside the connector for the o2 sensor and had pulled away just (unuff) how ever it's spelled
to not make the connection. once fixed, no more code.
__________________
Concrete is the cancer of our land,just give me dirt... |
