Question about Powersteering line
I see some of you have sleeved and welded your lines together. What material did you use to sleeve the joint? Brass, Galvanized...........? Did you guys MIG weld them or solder?
I just used some steel tubing from Lowes. I had to drill out the inside of the pipe a bit for the power steering line to fit snug in there.
I then mig welded it. Tig would be better but I have no access to that. My first attempt leaked badly, which I didnt know until the motor was started and PS fluid shot everywhere. Second attempt worked fine and is still holding.
the1998sr5
15
07-14-2020 08:35 PM
