YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Off Road Tech, Fab Shop, Solid Axle Swaps, Tool Time, & Engine Swaps > Engine Swap Talk > 3.4 Swaps
Home Photo Gallery Register Search Today's Posts Mark Forums Read Tread Lightly Wiki
Thread Tools Search this Thread Display Modes
Old 04-01-2008, 05:43 PM   #1 (permalink)
Redeyejedi's Avatar
Send a message via Yahoo to Redeyejedi
Manual vs Auto
so....i have the opportunity to also swap in an auto tranny but wanted some input on that. i have a 5spd and never considered an auto til a conversation i had with someone. it is my daily driver, plan to keep her forever, plan to SAS, and most of the wheeln will be trails/rocks/beach....
pros / cons of going auto?
Redeyejedi is offline
Sponsored Links
To remove this ad, register today!
Old 04-01-2008, 05:50 PM   #2 (permalink)
Dare44's Avatar
auto
pros:
easy to use
can do brake stances
Con:
not as reliable
loss of power
manual
Pros:
fun to drive
power
reliable
easy to bump it up rocks
Cons:
u have to shift?
__________________
1997 Toyota 4x4 SR5 4runner
3.4 auto
Toytec 3 inch coil spring Lift
Trail Gear Rock Sliders
Maxxis Bighorn M/T's
Amp Custom Rims
Cobra CB, 5ft Firestik
KC Daylighters
http://www.cardomain.com/ride/3008195
Near Future List
Bumpers
Lockers
1st Gen Roll Bar
Winning the Lottery?
Dare44 is offline
Old 04-01-2008, 05:52 PM   #3 (permalink)
WCorbett's Avatar
Ill trade you. Autos suck.
WCorbett is offline
Old 04-01-2008, 06:07 PM   #4 (permalink)
96redtoy's Avatar
here are the 4 most important things to consider
1. manual fun
2 auto very boring
3. M.anual= Man that think is a lot faster then my auto
4. A.uto= Ass kicked by a manual (plus they are girly)
__________________
96 tacoma stock
2.7L,
5speed,
manual locking hubs,
31x10.50
cobra cb
GO GATORS
Quote:
Originally Posted by Matt16 View Post
If a winch survives being hooked up to a Jeep, it should be more than enough for something that isn't always stuck, half-broken and barely working.
So, you're putting on 37" Iroks and you're worrying about ride quality? That's like a 500lbs chick worrying about one more smarty.
96redtoy is offline
Old 04-01-2008, 08:11 PM   #5 (permalink)
Redeyejedi's Avatar
if im on the rocks, am i more prone to breakage with a manual or an auto?
i agree 100% with fun and fast factor, relibility, less hp watsed, girly vs arrggggg.....i totally agree there. do any of you run out of revs while on a tricky climb? would an auto even remedy having to shift in that situation? i dont have much experience on rocks, so i am open to being schooled.
just for the record...i am a 5spd man but someone brought the point about shifting.
Old 04-01-2008, 08:21 PM   #6 (permalink)
nix4x4's Avatar
I don't know much about rocks, but I would say that neither
has more of a chance breaking because of rocks.
However, I would asume that a manual would still be desired over an auto
simply because its a simpler design, meaning its stronger and more reliable.
Plus, like stated above, a manual allows for greater likelyhood (sp?)
of making through a run, with the ability to bump it up and such, as well
as being able to play around with the clutch.
I personally would never want an auto on the trail, although I know many
who prefer it.
__________________
The Stable...
2002 Toyota Tundra SR5 AccCab V8 4WD
1992 Toyota Truck DLX Xcab V6 5-speed 4WD
1995 Honda Accord LX 4 door I4
Check out my sweet myspace
nix4x4 is offline
Old 04-01-2008, 08:26 PM   #7 (permalink)
96redtoy's Avatar
As stated above you will not stall with a auto. But with a manual when rock crawling it has no
slippage due to the fact of not having a torque converter your the one that controls slippage.
So that means as much power as you want to the tires as needed. None loss in the clutch packs,
hydrolic fluid and other crap in an auto. Everybody stalls when rock crawling its a fact of life.
Also when you over heat your auto and burn everything up that is a lot of money to repair.
Where overheating a manual is no issue cause it doesn't happen. And if failure happens in a
manual it is much cheaper to fix and much more do able by yourself
__________________
96 tacoma stock
2.7L,
5speed,
31x10.50
cobra cb
GO GATORS
96redtoy is offline
Old 04-01-2008, 11:35 PM   #8 (permalink)
Redeyejedi's Avatar
ok, good info.
one thing though, in terms of breakage, i was more referring to other parts namely brifs or cvs, inners or whatever due to exactly that power being less restricted. i suppose it's foot control. like i said, i had never considered an auto prior to that conversation i had. i appreciate all the input guys, thanks
Old 04-01-2008, 11:42 PM   #9 (permalink)
nix4x4's Avatar
Out of curiosity, what points were brought up in this conversation?
If you don't mind posting your personal life on the internet to complete
strangers, of course..
__________________
The Stable...
nix4x4 is offline
Old 04-02-2008, 12:06 PM   #10 (permalink)
Redeyejedi's Avatar
basically.....
all the points brought up in this thread were discussed as well as being stuck in tricky spots. we talked about climbing a steep incline a the possible need to shift. and how some rigs with autos and duals seem to just crawl right over stuff. i also imagine, you're also on the fat pedal a bit too cause the truck'll wanna just keep crawln while in gear.
Old 04-02-2008, 02:48 PM   #11 (permalink)
Redeyejedi's Avatar
thanks for the input guys!
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Manual or Auto 3.4L same? Chuki 95.5-2004 Tacomas & 96-2002 4Runners 13 07-02-2007 12:47 AM
Auto to Manual? bear92 84-85 Trucks & 4Runners 10 03-23-2007 06:10 PM
2.7 vs 3.4? Manual vs. Auto? Tokyota General Vehicle Related Topics (Non Year Related) 10 02-21-2006 06:43 PM
Auto Or Manual? Tacoma750 Offroad Tech 11 03-15-2005 11:59 AM
Auto or manual, which is best? Idaho_Jim 95.5-2004 Tacomas & 96-2002 4Runners 20 01-28-2005 07:09 AM
Powered by vBulletin® Version 3.6.4
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
2002-2008 Yotatech.com
