Thread Tools | Search this Thread | Display Modes |
#1 (permalink) |
Hood option's for a 3.4 swap.
Hi Guy's, Im doing my homework for a 3.4 swap at the end of the year, Im wondering what the option's are for the hood on my 93 4runner. I do want to add a supercharger also and didn't know if there were aftermarket companies that had pre fab hood's or does everyone just cut a hole in the center? Any advice and picture's will be greatly appreciated! Thank You.
| Sponsored Links |
#2 (permalink) |
I was able to get by (just bearly) without cutting a hole in the hood with a 1" body lift. But I had to take out the underhood insulation and cut out some of the cross bracing.
__________________
Dale "America is in a hole and it's getting deeper every day. We import 70% of our oil at a cost of $700 billion a year - four times the annual cost of the Iraq war." T. Boone Pickens Check out the plan: http://www.pickensplan.com/index.php and http://www.cngnow.com/EN-US/Pages/default.aspx |
#3 (permalink) |
Thank's for the reply Dale, Are you up there in Stillwater? Im hopeing on doing this swap in the fall, Be great if you were around for some question and answer's. Ill supply the cold one's and the grub.
#4 (permalink) |
Once I pulled my insulation, my hood actually closed without any body lift. It was tight, though, so I cut the hood and put one of these on:
http://www.amazon.com/Auto-Ventshade...6902&sr =1-17 I left it unpainted black and on my gray 4Runner, it almost looks stock. It's pushed right up to the washer nozzles. I should take a pic and post it sometime.
__________________
1991 4Runner, 3.4 5VZFE swap, OME shocks/springs, 33" BFG All Terrain T/A KOs, Pioneer head unit, Infinity speakers, XM Satellite radio |
#5 (permalink) |
when you say "barely" you aren't kidding, that is close
__________________
As well as fear, Chuck Norris can also detect hope. For example: "I hope I don't get a roundhouse kick to the face from Chuck Norris." 1993 Ex-cab 4x4 3.0 5spd, 140xxx mi. and counting, AND YES, IT DOES HAVE A TAPE PLAYER |
#6 (permalink) |
A pic would be great, Thank's Rob.
#7 (permalink) |
How much higher does the engine with the S/C sit compared to just the 3.4 buy itself?
#8 (permalink) |
everyone i know does a 2inch body lift and it clears fine.
__________________
my truck new my truck now with TRD wheels and exhaust 93 toyota 3.0 manual trans. toyota!! the trucks that gave the trails a rating |
#9 (permalink) |
Are there any con's with doing a 2 inch body lift? Thank's for the reply ToyTech.
#10 (permalink) |
not to my nollage. my friends truck has the 3.4 and supercharged. he just did the body lift and it works great and looks good to boot.
__________________
#11 (permalink) |
Sweet Thank's.
#12 (permalink) |
Staff
x2. Would like to see how the end result turned out.
Probably depends on what you are planning to do with the vehicle. You'll have to deal with some other mods like shift levers and steering rod. Generally something that isn't to bad, but can add some complications. I ended up cutting a small hole. Simple enough for now: ![]() I don't have a body lift or a supercharger. Breknraj did a really nice mod to his hood also... but I can't find the thread about it. I thought it was in his 3.4 swap. Maybe he'll chime in or PM him for some more info.
__________________
================ 1990 4Runner | V6 3.4 | 5spd | 240 someoddthousand miles | SR5 | SAS | RLS | 35's | ARB | TJM | 217 to 1 | W8000 - four wheels | three sticks | two hands | one trail - |
#13 (permalink) |
X2 on the pic.
Marine, I'm actually in Edmond, but my heart's in Stillwater. Sure, anything I can do to help a Jarhead. Ooooh rahhh! ![]() BTW here's the 3.4 swap section: http://www.yotatech.com/f160/ It's kind of hard to find.
__________________
Dale "America is in a hole and it's getting deeper every day. We import 70% of our oil at a cost of $700 billion a year - four times the annual cost of the Iraq war." T. Boone Pickens Check out the plan: http://www.pickensplan.com/index.php and http://www.cngnow.com/EN-US/Pages/default.aspx Last edited by mt_goat : 01-12-2008 at 09:01 PM. |
#14 (permalink) | |
Quote:
http://www.4crawler.com/4x4/ForSale/ProductLine.shtml
__________________
#15 (permalink) |
I am gonna be doing a 2nd gen black s/c 3.4 swap into my 90 and I am thinking about cutting the hood and putting a CHEVY COWL INDUCTION SCOOP on and glassing it into place it measures out fine will fit perfectly between the washer things and fits the natural beds of the stock hood.
__________________
1990 4 runner 5 Speed Pro Comp Stage II 4" Lift 6" coils rear Aussie Locker front 5.29's Front And Rear 35 x 12.5 x 15 MT's Micky Thompson Classic II Wheels Super Charged 3.4 on the way 1993 SAS 4runner 22re 5 speed 4" front 5"rear 5.29's 35 x 12.5 BFG KM'S Dick cepek DC 1's 1955 Harley Davidson Springer Stock 1955 Hardtail Frame 4 Speed Kick Start Only Streached 5.5 gal. tanks 16" Ape Hangers 3" open primary 1998 Harley Custom Dresser 107 rwhp 139 ft.lbs.trq. |
#16 (permalink) | |
Quote:
#17 (permalink) |
So i guess no one make's a aftermarket hood for the 4Runner's.
#18 (permalink) |
Any pic's off diffrent hood scoop's would be great too. Thank's.
#19 (permalink) | |
Quote:
Thanks for your service to our country BTW. Lets roll ![]()
__________________
#20 (permalink) |
hood scoop
I used a smaller copy of the Mustang scoop (Evil-bay $40). Long-term plans call for a cowl-hood. I don't have any body lift, so I needed to trim about an 8x10 offset hole in the hood.
__________________
93 4 Runner / 3.4 swap / R151F swap / cash swap / 285-75-16 Revos / SDORI 1.5 BJ spacers / OME 900s |
