guys with working AC, do you have a clicking noise?
Old 06-13-2012, 05:58 PM
QuickSilver74's Avatar
i wired up my AC with the sticky on here (the updated one) when i have my AC running and i am coming to a stop with the brakes applied i get a clicking noise from behind the glove box. it will go away if i turn the ac off when it starts making the noise and as far as i know it doesnt ever make the noise other than when i am stopping. any idea what it might be?
Old 06-14-2012, 04:35 AM
vasinvictor's Avatar
Does your compressor cycle on and off when the clicking occurs?
Old 06-14-2012, 05:46 AM
93NMyota's Avatar
Mine does that sometimes and I don't know if quicksilvers is the same but my compressor does cycle on and off when that happens, I know i saw it somewhere on here but i was curious about that adjustment behind the glove??
Old 06-14-2012, 03:20 PM
Discombobulated's Avatar
Mine clicks under dash when it cycles and I only notice it when I stop but I listened real careful while driving and it still does it I think from road noise, engine noise it drowns it out and when you stop you can hear it better.
Old 06-14-2012, 03:30 PM
I guess I should have said mine makes no audible clicking that I've ever heard.
Old 06-15-2012, 02:32 PM
i will look for the adjustment for it and see if that changes anything. does anyone have a pic or write up of how to adjust it?
Old 06-15-2012, 07:39 PM
technojunkie's Avatar
I'm not sure about the v-6 but the 22re amplifier has a knob that sets a cut out rpm. It works with the idle-up system to keep the a/c from running at too low an rpm. It's also possible you have too little or too much refrigerant and the pressure switch is cycling the compressor relay.
slider417
06-22-2015 10:18 AM
UKMyers
11
06-24-2002 05:41 AM
94 First Responder
05-31-2002 09:07 PM
Quick Reply: guys with working AC, do you have a clicking noise?
