Thread Tools | Search this Thread | Display Modes |
#1 (permalink) |
Fuel line and fuel return hose question
Both my High pressure fuel line and my fuel return hose were cut when the engine was removed.
I am planning on using the ORS kit and was wondering if I am going to have to replace these two lines with new ones since they are missing the factory connections. Thanks. I'm not sure how the 3.4 and the 3.0 lines get connected together in the swap so maybe it's not an issue. Just trying to get as many of the details worked out before I dive into this. Of course I suppose it will be self evident what I need to do once the kit is in my hand but I was looking at the lines today and wondering if that is going to be a problem.
__________________
1995 Toyota PU SR5 V6, A few mods. |
| Sponsored Links |
#2 (permalink) |
This is one way http://www.andrewzook.com/content/view/22/48/1/9/
I went another route and spliced mine together with high pressure couplings. No problems to this point. If I can find out the manufacturer, I'll post it here. Same with the return hose, but it's not high pressure, so it's a bit safer.
__________________
1991 4Runner, 3.4 5VZFE swap, OME shocks/springs, 33" BFG All Terrain T/A KOs, Pioneer head unit, Infinity speakers, XM Satellite radio |
#3 (permalink) |
Thanks. I was looking at that option earlier. I was just thinking since ORS supplies the line in the kit anyway it would be nice to be able to just bolt it on. I guess I'm going to need another line then. Time to hit the pick n pull. For the high pressure line anyway. For the return line I may just splice it like you did.
Man all these little items are starting to add up. This motor wasn't quite as "complete" as I thought it was.
__________________
#4 (permalink) |
They cut the line when they pulled mine. I cut mine to match, then used a coupling and proper hose clamps (NOT heater hose style clamps, they won't hold and you'll probably roast your truck to the ground). Not really a big deal. The return hose can be standard fuel hose.
__________________
#5 (permalink) |
Ya really not interested in roasting my truck. LOL! I'm going to see if I can get a stock uncut line somewhere that won't cost an arm and a leg. Failing that, where did you get the splice and "proper" clamps from?
__________________
#6 (permalink) |
Lordco in Kelowna. My brother works there. I'll have to ask him the brands on them.
__________________
#7 (permalink) |
A stock 3.4 fuel hose will work fine with the conversion - it just needs to be rotated 180* on the fuel rail, so that it points toward the passenger side. The fitting on the end of the hose will thread right on to the fuel supply fitting in the engine bay.
The return hose was just a matter of running a new length of fuel hose from the engine to the return line - simple.
__________________
Raj : 1960 Homo Sapien. 192cm, Blonde, Blue. Soon to lose spare tire. Worf : 1990 SR5 Xtracab 4x4 5 speed, Inca Red Metallic. 3.4 converted, with Taco 5 spoke alloys, 275/65R16 BFG AT K/Os. Soon to add rear e-locker. |
#8 (permalink) | |
Quote:
#9 (permalink) | |
Quote:
__________________
#10 (permalink) | |
Quote:
__________________
#11 (permalink) | |
Staff
Quote:
I have more detail on page 3 if you scroll down a bit: http://www.yotatech.com/f160/elvota-...85/index3.html I realize the OP's OEM lines have been cut, but I think I'd scrounge a salvage yard or two first to see what I could dig up. Mind you, if the yards in your area are anything like ours... finding a 3.4 is going to be next to impossible.
__________________
================ 1990 4Runner | V6 3.4 | 5spd | 240 someoddthousand miles | SR5 | SAS | RLS | 35's | ARB | TJM | 217 to 1 | W8000 - four wheels | three sticks | two hands | one trail - |
#12 (permalink) |
Well the local pick n pull will sell me an uncut one for $25. So I'm going to get that. It looks plenty long enough to reach the 3.0 line. thanks guys.
__________________
#13 (permalink) |
Great!
For what it's worth, I had good luck with D&M Recyclers. They're the guys I got my 3.4 from in BC. http://www.autorecycling.com/ They get e-lockers in from time to time!
__________________
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Fuel line? Fuel pump? Fuel injector? | MikeKaduce | 86-95 Trucks & 4Runners | 3 | 11-06-2006 07:21 PM |
| Fuel return and Fuel evap swapped? | AJatx | 95.5-2004 Tacomas & 96-2002 4Runners | 10 | 06-14-2006 01:20 PM |
| 22re fuel return line...where does it go? | jscarrozzo | 95.5-2004 Tacomas & 96-2002 4Runners | 1 | 08-19-2005 01:48 PM |
| Fuel line question | Citykid | 95.5-2004 Tacomas & 96-2002 4Runners | 8 | 08-07-2005 02:27 PM |
| '85 EFI 4runner fuel return line? What is Spring W/plastic cap by cs injector | slojo | 95.5-2004 Tacomas & 96-2002 4Runners | 4 | 02-20-2005 05:28 PM |
