| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#276 (permalink) | |||||
__________________
86 4Runner, custom Sonoran Steel rear bumper, 4Crawler 1" body lift, rock sliders from Richard Stubbs, rear Lockright, SAS w/ARB My build thread. http://www.yotatech.com/f66/blknblu-s-sac-155872/ |
#277 (permalink) |
Where can I find the info on where to splice the jasonbox into the truck? I am building one but I am not quite sure where I should be looking and what I am looking for to splice into. I have a 98 4runner with 3.4.
#278 (permalink) | |
Quote:
Just have to splice the box in somewhere between the ECM and the secondary O2 sensor. I chose under the hood as it was offered some protection from the elements there.
__________________
================ 1990 4Runner | V6 3.4 | 5spd | 240 someoddthousand miles | SR5 | SAS | RLS | 35's | ARB | TJM | 217 to 1 | W8000 - four wheels | three sticks | two hands | one trail - visit the sticki chronicles
#279 (permalink) |
I spliced in at the back of the ECU.
__________________
~Dale~ 93 4X4 ext-cab, auto, SR5, 3.4 V6, supercharged, 2.1" pulley, URD fuel mods, Aquamist WI, IPT valve body mod, dual cases, 4" superlift front, Alcan springs rear, 33 BFG MT, ARB locked front & rear, 5.29 US Gears, RB 1" Body Lift, 1.5" ball joint spacers, manual hubs, TJM T-17, Warn m8000. |
#280 (permalink) |
Elvota, I'm finishing up details like routing stuff today, and remembered you used a Marlin brake line for your clutch. I hooked up the stock line with the ORS bracket today, and I think I like your way better. What was the original applilcation for this line from Marlin?
__________________
Jonny 1990 3.4 5spd 4Runner, 33" BFG KM2's 1983 5spd Shortbed, 35" BFG M/T's with no lift! Soon to be...who knows, but the 35's ain't stayin! "If at first you don't succeed, skydiving's not for you." -Unknown |
#281 (permalink) |
It was just one of their braided brake lines. You'll have to make sure you get one with ends that match your application. Male to Male, Male to Female... what ever you need.
__________________
#282 (permalink) |
I'm starting my 3.4 engine swap and was wondering what you had to swap around in the engine bay. Any charcoal canisters etc. I know you have to move the battery tray, but what else did you have to move around? I have read through your swap and it is one of the most detailed of them all. Cause of your thread it has persuaded me to do mine. Thanks
#283 (permalink) |
I've covered most of what is required in this thread, but I ended up reusing the original 3.0 charcoal canister so that wasn't relocated. The intake moves but that's straightforward since the 3.4 runs everything out the PS and you just have to follow it's lead.
Best of luck... it's more than worth the effort.
__________________
#284 (permalink) |
AWESOME THREAD!! Just spent an hour rereading it for the third time.
Curious if you ever got the ac installed and working and if you did a write up on that. If not, any advice, tips, concerns that we should be on the lookout for? Awesome job!
__________________
1992 Toyota Pickup Ex-Cab 3.0 V6 4" Pro-Comp lift |
#285 (permalink) |
Staff
Elvota is rarely on YT now as he is focusing on Mt Bike Racing.... Just an FYI. But this IS an invaluable thread!
__________________
Molly aka Lysmachia 93 4 Runner SAS (Tippy) - All Broken in Junk Yard Goodness Get your 4x4 VIDEO pr0n here |
#286 (permalink) |
i couldnt seem to find anything mentioning this so i figured i would ask here.. if i have a 4 inch lift on my 95 yota do i still need to change out the oil pan?
__________________
98 Tacoma Sr5 v6, 33x12.50x15 Cooper St's, 3" body, 2.5" Pro Comp leveling kit - Update - Rolled over - R.I.P. 1/24/09 |
| Tags |
| 1991, 34, 34l, 4runner, 5vzfe, 95, belt, compatibility, diy, guide, speed, spline, swap, timing, toyota, ts26271, writeup |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Elvota's '90 SAS 4Runner | Elvota | 4Runners-2nd gen | 3 | 12-28-2007 03:39 PM |
| 1991 4Runner body swap or engine/tranny swap? | 91slowrunner | 86-95 Trucks & 4Runners | 2 | 05-21-2007 10:11 PM |
| 3.0 to 3.4 swap?s | 91truck | 86-95 Trucks & 4Runners | 5 | 03-26-2007 08:41 PM |
| Axle/Gear Swap Help: Will a '94 Auto-V6 4x4 axle swap into my '90 22RE-5spd 4x4? | Justin311 | 86-95 Trucks & 4Runners | 15 | 04-15-2006 12:18 AM |
| 4wd problem/tranny swap/t-case swap wtf | squishy321 | Offroad Tech | 2 | 04-01-2005 11:41 AM |
