Elvota's 3.4 swap
Old Dec 11, 2007 | 08:48 PM
  #201
Elvota's Avatar
All right... more results. Betting you are all just chomping at the bit, anxiously waiting to get my 4Runner running again.
The B-Y wire from the ignitor to the ECM checks out good. No breaks. So, IGf signal from the igniter can reach the ECM.
Then I tried this test from the FSM 111db posted up:
"Disconnect Black 10-pin ignitor connector. Access ECM behind glove box. Turn ignition on. On M/T models, measure voltage between ground and terminal No.17 (B-Y wire) on the ECM. On all models, if voltage is 4.5-5.5 volts, replace ignitor. If voltage is not between 4.5-5.5 volts, replace ECM and retest."
There is no real way for me to access terminal No.17 (B-Y wire) on my ECM from behind the glovebox. Maybe on a '96, but not on my '90. However, since No.17 from the ECM is the B-Y wire leading to the ignitor plug, I concluded that I could perform the same test by checking how many volts there were between the B-Y pin and ground pin on the igniter plug with the ignition switch on.
If everyone agrees that this is a valid version of the FSM test, with my result of 5.0 volts, I need to replace the ignitor.
Does anyone think my results would be different if I actually connected to terminal No.17 (B-Y wire) at the ECM? Do volts drop from the ECM to ignitor plug at such a level that my test would be wrong? Even if they do drop somewhat, since I tested 5.0v... seems like I am right in the middle of the range, and need to replace the ignitor.
I'll except everyone's answer to these questions as unbyased except Willcipher's... as he stands to make $30, and maybe even gain a 6-Pack.
Although Will, I'd still very much like to hear your opinion on my testing process, results and conclusion. Would be worth the extra money to turn my 4Runner back from a lawn ornament to a trail worthy rig.
Old Dec 12, 2007 | 03:05 AM
  #202
Bighead's Avatar
Originally Posted by Elvota
Is there a whole part of the FSM with various "Tests with Codes"? If so... I am missing a lot of helpful tips, tests and info.
That info is in the Diagnostics-Engine (5VZ-FE) section.
Old Dec 12, 2007 | 05:50 AM
  #203
Willcipher's Avatar
You should have no observable voltage drop between the ECU and the igniter; therefore your test for voltage at the igniter should be valid.
As Bighead stated, the diagnostics section contains detailed info on testing individual components. Check it out when you get a chance.
Test everything between igniter and ECU before condemning either one. let me know if you need the igniter and I'll get it shipped out to you tomorrow.
Paypal is preferred- willcipher@yahoo.com
Old Dec 12, 2007 | 09:41 AM
  #204
Elvota's Avatar
I don't have the diagnostic sections of the FSM. Must have missed those when I was signed on to TIS.com. I may have to log back on and grab them.
111db, your previous post stated: "Check for spark at misfiring cylinder. See ignition checks in F - Basic Testing". I'd like to complete the tests in order, but I am not sure what the FSM is recommending to do in the first step.
If it is not to much trouble, could you post or PM me the procedure for "checking spark" as referred to in the FSM?
Thanks.
Old Dec 12, 2007 | 03:13 PM
  #205
Bighead's Avatar
Steve, Just in case you this first...I sent the DI-Engine section. Let me know if you need any other parts.
Old Dec 12, 2007 | 03:50 PM
  #206
toy_tek's Avatar
I just emailed a few sections as well.
Old Dec 12, 2007 | 04:05 PM
  #207
Elvota's Avatar
Thanks both Lance and Jon. Really appreciate it. Just glanced at the first few files and really think they are going to be a big help.
Especially if I have more issues going on than a possible bad ignitor.
Old Dec 12, 2007 | 04:22 PM
  #208
toy_tek's Avatar
Something tells me to doublecheck that code... maybe reset the ECU and see if you are getting the same thing? Nothing worse than troubleshooting in the wrong direction... not that you are... but just to be sure you aren't.
Back in the day of counting flashing engine lights (87 22RE after a rebuild), I spent two days chasing my tail only to find on day three there was a different code after I reset it... I had the only two interchangable connectors on the entire engine harness swapped. 2 minute fix at that point. uggh. I only share this because you are not alone in your frustration.
Old Dec 12, 2007 | 04:50 PM
  #209
Elvota's Avatar
Thanks for the advice. I am leery of the code being the end all, be all of my issue. If the motor at least ran, I'd have a little more faith that the ECM had some time to see what was wrong.
I also don't like that the code that shows up seems like it's right at the beginning of the ECM's cycle. I wish it was a little further along, so I at least new the ECM was working and some connections were correct. But I am not entirely clear of the diagnostic system... learning a bit more everyday.
I had disconnected the battery overnight before trying to start the motor several times... and then using the OBDII scanner came up with the P1300 code. But it would be easy enough to reset the ECM again and see if I get the same code.
To be honest, the possibility of a component being to blame with my truck seems more unlikely than the possibility that I have wired something incorrectly. Of course, I have to follow all possible leads at this point to solve the problem.
I'll do a few more tests and see if they also point to an ignitor issue. I also plan to get some type of OBDII interface to a laptop to try and get a better idea of what is actually going on.
Everyone please keep any ideas, tips or advice coming. I definitely find the input very helpful.
Old Dec 12, 2007 | 08:06 PM
  #210
wormhole's Avatar
You know Steve I've heard that a baseball bat can work wonders .
Good job on the swap. You'll get it. Tim needs to reopen the Az trails .
Old Dec 12, 2007 | 08:23 PM
  #211
Elvota's Avatar
Hmmm... I'll have to add one of those to my toolbox.
Old Dec 13, 2007 | 09:27 AM
  #212
westy44runner's Avatar
yeah, put that right next to the hedge clippers
Old Dec 13, 2007 | 09:47 AM
  #213
Elvota's Avatar
I'd bet the shrubbery is not rooting for me to get this 3.4 running....
Old Dec 13, 2007 | 04:52 PM
  #214
Elvota's Avatar
Many times I have been out on my bike, or hiking with the dog and girlfriend with an impending storm closing in. Over the final ridge line I always see the 4Runner as a beacon of hope. A place to rest, get out of the weather and escape the dark. It's always so rewarding to turn that key and just drive away.
But never has a key turn been so rewarding as it was this evening.
My fellow YT hombres...
WE HAVE......... A RUNNING ELVOTA !!!!!!!!
And it was all from one hiding, cowardly, stinkin' no good lilly lovin' loose wire at the ignitor plug.
Actually, I was going through the FSM testing procedure I had so graciously been E-Mailed behind the scenes, starting to look for continuity. Suddenly, the IGC2 signal wire from the ECM to coil No.3 looked bad.
For those who don't know, the ignitor plug is a well sealed unit. A little rubber grommet at the entrance of each wire to the plug. Nothing more than the slightest tug and the troubled orange wire just slipped right out. To think, orange is even my favorite color.
Anyway, after struggling with the pin forever, I was finally able to reconnect this little so and so and turn the key to instant fire up. Coolest thing is the issue wasn't even something I did wrong or forgot to do. Very stoked, very stoked indeed.
Of course, I still have many loose ends to tie up and actually drive the thing on the road... then trail, but I feel really confident things will be good to go. I'll post details on my final wiring when I am sure things are done correctly.
Ton of thanks for all of the help. Really appreciate everyone's time and effort. I wouldn't have even given this a shot if I hadn't done so much research here first. Looks like Will was all over this.
For the locals, I am still not so sure if I will try Martinez. I need to get everything else on the vehicle done, and would like to get some actual driving miles before I hit the trails. But, we will see... we will see.
If not, I'll drive to your houses one by one so you can check it out. Will be a great excuse to drive this thing.
Old Dec 13, 2007 | 05:22 PM
  #215
Bighead's Avatar
Great news Steve!
Old Dec 13, 2007 | 05:33 PM
  #216
mt_goat's Avatar
Hallelujah!
Old Dec 13, 2007 | 06:37 PM
  #217
sschaefer3's Avatar
Yellow Belly Ledge Awaits. If you can't follow a BBQ grill..........
Old Dec 13, 2007 | 07:07 PM
  #218
breknraj's Avatar
Congrats, Steve!!
I'm already amassing a bit of a list of things to do when I yank mine out, again, next spring! This damned modding bug is a bear to deal with!!
Old Dec 13, 2007 | 07:16 PM
  #219
AZ4ME's Avatar
Nice job Steve. Is it okay for me to drop my truck off on Monday?
Old Dec 13, 2007 | 07:43 PM
  #220
Elvota's Avatar
Originally Posted by Bighead
Great news Steve!
Most definitely.
Originally Posted by mt_goat
Hallelujah!
You said it brother.
Not sure if the first thing I want to try is a finesse move with all this new HP... but maybe I'd just jump right off the top. "Yellow Belly Launch"
You are gonna yank it out again? Man, I am so happy to have mine in and running I can't imagine. I do know what you mean about modding though. I already have a few more for myself in mind. Terrible disease this, just terrible.
Monday... way to early. Wednesday though for sure. You bring the 3.4, I'll do the rest.
