YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Off Road Tech, Fab Shop, Solid Axle Swaps, Tool Time, & Engine Swaps > Engine Swap Talk > 3.4 Swaps
Home Photo Gallery Register Search Today's Posts Mark Forums Read Tread Lightly Wiki
Thread Tools Search this Thread Display Modes
Old 04-23-2008, 09:46 AM   #1 (permalink)
TURTLE GREEN's Avatar
3.4 Swap Help!!
Im looking to sway a 3.4 into my 89 and i can get a 3.4 with the whole harness and computer with a 90 day warranty on it for 750 but its backed behind an automatic. i heard somewhere that you cant use the ones backed behind an auto because the manual pilot bushing wont work, is this true?
TURTLE GREEN is offline
Sponsored Links
To remove this ad, register today!
Old 04-23-2008, 10:30 AM   #2 (permalink)
Staff
Elvota's Avatar
There has been some off and on debate as to whether all 3.4 crankshafts have been machined to accept the pilot bearing. It's my understating that it has been determined that all 3.4's actually have this hole in the crank, so you should be good to go.
However, using a 3.4 Auto ECM with a 5SPD can be problematic. Would require a better understanding of the wiring than what I have. You could always find a 3.4 Manual ECM... but that's going to add to your costs.
__________________
1990 4Runner | V6 3.4 | 5spd | 240 someoddthousand miles | SR5 | SAS | RLS | 35's | ARB | TJM | 217 to 1 | W8000
- four wheels | three sticks | two hands | one trail -
Elvota is offline
Old 04-23-2008, 10:50 AM   #3 (permalink)
very true never thought about that, thanks for your help man
Old 04-23-2008, 07:10 PM   #4 (permalink)
yotaman's Avatar
All 3.4's have the hole. 95-97 wiring harness's have differnt plugs for auto and manual ECU's. You can use an auto ECU to get the motor to run.
__________________
Greg - http://www.pureyota.com --- you can't fail if you don't give up.
Proud dad of a little girl..
1. 1997 Tacoma - 3.4 auto - SAS'd - DD
2. 1995 4Runner - SAS'd - FJ62 Front - FZJ80 Rear, 40" Iroks - Beater!
3. 1995 4Runner - 3.4 swapped - Baby mobile/Grocery getter!
You can lose a lot of money chasing women, but you'll never lose women chasing money.
yotaman is offline
Old 04-23-2008, 07:25 PM   #5 (permalink)
Staff
UKMyers's Avatar
Send a message via AIM to UKMyers
Pilot bearing in the SEARCH yielded 360 threads. I could have answered your question with about 8 of the first few threads that it popped up with.
__________________
2006 Tacoma TRD offroad 4.0 Access Cab 6 sp 3" Revtek, 285 BFG's, Borla Catback, Volant Intake, Billet Grill, Split Second PSC1 Professionally dyno tuned, URD Short Shifter Kit, 226 RWHP
1994 4-Runner SR5 5 Speed SASed, Detroits, Armored, Dual Cases, 37" MTR's See my build up thread here http://www.yotatech.com/showthread.php?t=104000
Quote:
where on the 3vze manual is the transmission dipstick?
Quote:
what is sas?
UKMyers is offline
Old 04-24-2008, 11:25 PM   #6 (permalink)
JGrund85's Avatar
If you don't mind seeing about 8 check engine lights the auto wiring harness and ECU will work just fine...that being said I am still having some issues with getting mine to run. I had yotaman build me a plug and play harness. Worked really well since I hate wiring things myself and spending hours looking at wiring diagrams.
__________________
91' 4Runner, 3.4L swap, SAS, 4" front 5" rear trail gear lift, 5.29's, detroits front and rear, sliders, 1st gen roll bar, Longfields, Addicted Offroad front winch bumper, 35x12.50x15 Mickey Thompson Baja MTZ's
JGrund85 is offline
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
1991 4Runner body swap or engine/tranny swap? 91slowrunner 86-95 Trucks & 4Runners 2 05-21-2007 10:11 PM
Axle/Gear Swap Help: Will a '94 Auto-V6 4x4 axle swap into my '90 22RE-5spd 4x4? Justin311 86-95 Trucks & 4Runners 15 04-15-2006 12:18 AM
3.4 swap Manson 95.5-2004 Tacomas & 96-2002 4Runners 4 10-20-2005 08:44 PM
4wd problem/tranny swap/t-case swap wtf squishy321 Offroad Tech 2 04-01-2005 11:41 AM
3.0 to 3.4 swap s_wall98 95.5-2004 Tacomas & 96-2002 4Runners 12 07-09-2003 10:57 AM
Powered by vBulletin® Version 3.6.4
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
2002-2008 Yotatech.com
