22ret t0 3.4 swap help
I removed the auto harness and i am on the hunt for a complete manual harness I might put this harness on ebay with the ecu. Can I just get a harness for manual trans for any year 3.4? I called the a dealership and they foundout my auto ecu and harness is out of a 96-97 4runner and my manual ecu is a 96-97 Tacoma. They told me there is 8 diffrent harnesses for the manual alone. Any help please...
I was able to order a matching manual ecu harness from toyota bring in the ecu and see if they can order one. Chances are if there is one. its gonna come from japan. That missing plug needs to come from a similar model year and style rig and needs to plug into the ecu. If you cant find one, you maybe able to order just the plugs for the ecu and order a bunch of wire leads for the plugs if your pins wont transfer over.
When I talked to the dealer they want a vin from the doner they told me there was no way to tell the model from the ecu I will try another toyota dealer and see.
I found out I can run the automatic ecu with the automatic harness with a manual tranny I am just hunting for the 4th plug that plugs into the ecu. If anyone knows where to get one could you let me know. We have no wrecking yards around here.
lbhsbz
07-13-2011 10:23 AM
minerdude1
06-07-2009 07:02 PM
