| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
22r (not RE)-3.4 fuel delivery questions
#2 (permalink) |
so what are the stock 3.0 trucks running?? What are the specs on the stock pump??
#3 (permalink) |
I used the stock system from my 3.0, the only thing I had to do was use ORS's little blue hose with the adapters to make the 3.4 fuel line reach the 3.0's frame mounted line. As far as the specs on the stock pump, I don't really know, but I've heard of people using the stock RE pump, unless they supercharge. Maybe the FSM has the specs?
Edit: Found the specs in the FSM Fuel pressure: 265 – 304 kPa (2.7 – 3.1 kgf/cm2, 38 – 44 psi)
__________________
Jonny 1990 3.4 5spd 4Runner, 33" BFG KM2's 1983 5spd Shortbed, 35" BFG M/T's with no lift! Soon to be...who knows, but the 35's ain't stayin! "If at first you don't succeed, skydiving's not for you." -Unknown Last edited by JonnyBoy; 07-10-2009 at 01:07 PM. |
#4 (permalink) |
Thanks, thats a start at least..
#5 (permalink) |
Check Slacker's (Corey) build up on his Trekker. He swapped in a 3.4 and supercharged it. There are some details about using an aftermarket fuel pump.
__________________
1991 4Runner, 3.4 5VZFE swap, OME shocks/springs, 33" BFG All Terrain T/A KOs, Pioneer head unit, Infinity speakers, XM Satellite radio |
