removing tint
removing tint
hey all,
im trying to remove the tint on my runner and i dont want a shop to do it due to the fact that they charge outragous prices.
how do i go about doing this on my own?
needayota,
is it on the front window? if so, the easiest way is to tape a garbage bag aroudn the window and then spray 409 in there. it loosens the film adhesive. wait 15-30 minutes and then repeat at least one more time.
it should just peel right off in a long sheet. if not, it will come off in two sheets
have a scraper ready with plenty of razor blades.
if you're working on any areas with heater lines, do not use the razor blades.
bob
bob
1. put a black garbage back on the outside of the window (you may have to tape a few together). using a razor blade, cut the bag to fit the shape of the window.
2. spray the window tint with ammonia.. the more pure, the better.
3. spray the trash bag, then stick the wet side against the window tint.
4. let it bake in the sun for 30 minutes.
5. pull it off.
make sure not to just pull the trash bag off at once. reveal small pieces while you are peeling the film. you may need to spray a little more ammonia while you are peeling... a gas mask will be highly desirable.
I've used this method a few times and it works like a champ... just don't get gassed out.
5. pull it off.
Originally Posted by NX Tacoma
Well my idea sucked!! :pat:
HA HA HA!
HA HA HA!
You can also use Windex or other ammonia cleaner to lubricate your razor blade as you go across the glue on the glass. Peeling works great but I've never removed all the glue with the above method.
5. pull it off.
5. pull it off.
This is the way I removed my tint in the past.
Works great!
Hehe. I tried the razor blade once. After that, my new window scratches inspired me to find a better way
LotOMiles
09-14-2015 11:45 PM
Rickstwowheels
09-09-2015 06:12 PM
