leaking cv boots
Old 06-05-2005, 09:10 AM
Rishi's Avatar
leaking cv boots
Anyone knows if the slight leakage in the CV boot and upper a-arm ball joint boot leakage is serious.
2003 4runner, 37k miles
Rishi is offline
Old 06-05-2005, 09:16 AM
superjoe83's Avatar
i wouldn't worry about it
superjoe83 is offline
Old 06-05-2005, 02:20 PM
gman72's Avatar
On a 2003? With 37K mi.? Should be covered under warranty - take it to the stealer for a looksy --- personally I'd demand they fix it (that is, assuming the "leak" coming from your CV boot isn't from puncturing it on a rock or something)
gman72 is offline
Old 06-05-2005, 06:47 PM
Rishi's Avatar
The CV boots are fine. The grease is bleeding from where it is strapped to the rod.
Rishi is offline
Old 06-21-2005, 09:54 AM
Godzilla's Avatar
if the grease is bleeding at the rod and there are no tears what is the best solution to this? replace the boot and regrease or is this even a big problem?
Godzilla is offline
Old 06-21-2005, 10:42 AM
mt_goat's Avatar
I had a CV boot leak while I was under warranty too. It was replaced by the dealer no charge. I guess if you have lifted the front and put the CV at an extreme angle they could refuse to cover it under warranty if they wanted to, so be nice and polite if that's the case.
mt_goat is offline
Old 06-21-2005, 11:01 AM
Good Times's Avatar
is the front up on jack stands or something? cuz that cv angle doesn't look healthy for a 4th gen.
otherwise everything looks normal to me.
Good Times is offline
wafoogalla
11-02-2016 11:02 AM
BeMiceElf
10-10-2015 09:40 PM
ia02
08-20-2015 11:04 AM
makemusic116
08-02-2015 05:23 PM
makemusic116
08-02-2015 04:40 AM
Quick Reply: leaking cv boots
