ignition probs
Old 06-21-2005, 08:01 AM
Neeck89SR5's Avatar
ignition probs
I'm having alot of problems with my 3VZE in an 89 SR5 4runner. My truck idles decently but at about 1600 rpm the ignition voltage drops off completely. The ignition cuts back in at about 1100 rpm. I have replaced the ignition system almost completely, new cap and rotor, new coil, "new ignitor" (salvaged but guaranteed), plugs and wires. I looked at the ECU nothing obviously wrong. Its about time to change my t-belt, and I have had suggestions to check my throttle position sensor. Any help would be appreciated.
Neeck89SR5 is offline
Old 06-21-2005, 08:04 AM
Guest
94x4's Avatar
Check the TPS, as "...suggested...".
94x4 is offline
Old 06-21-2005, 08:29 AM
Neeck89SR5's Avatar
Any diagnotic help, How would I check it?
Old 06-21-2005, 08:34 AM
Guest
94x4's Avatar
Use the "Search" feature to look up "throttle position sensor" is the best "diagnostic help" that I can give you, others may have more.
94x4 is offline
Kamaloha
10-16-2015 05:13 PM
zombie_barbarossa
10-02-2015 10:54 PM
Rerun
3.4 Swaps
10-01-2015 12:24 PM
bryan34w
12
09-30-2015 02:50 PM
voiddweller
09-28-2015 11:21 PM
Quick Reply: ignition probs
