Chirping/Squeeking from Transmission? - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > Maintenance & Repair Archives
Welcome to Yotatech!
Welcome to Yotatech,
Old 05-29-2005, 11:00 PM   #1 (permalink)
SC4Runner's Avatar
I've had this chirping noise coming from under my truck for the past few months.
It happens when:
1) I have been driving a lot
2) When Im coasting down a hill
3) Driving around 30 miles per hour when I barely have my foot on the gas
Its annoying as hell.
I thought it was my front diff for a while, but, I dont think it is. I thought it was coming from my wheel wells but, it appears to be coming a little further back towards the middle of the truck.
__________________
1996 4x4 3.4L 4Runner on 35's - 6" of lift, MTR's, E-locked, ARB Tacoma Bumper, Sliders and a cut off tail pipe.
1966 FJ40 - SOA with stock springs, stock 1F motor, and a smelly tailpipe.
SC4Runner is offline
Old 05-30-2005, 09:52 AM   #2 (permalink)
Have you checked the universal joints?
pat161 is offline
Old 05-30-2005, 10:29 AM   #3 (permalink)
SC4Runner's Avatar
Good point. I was thinking about seeing if they needed some lube.
I need to go buy a grease gun and try that.
Any other ideas?
__________________
Old 05-30-2005, 11:13 AM   #4 (permalink)
rimpainter.com's Avatar
Is it a 5-speed? If so, this is a known problem. Let us know if it is, we can tell you more.
rimpainter.com is offline
Old 05-30-2005, 11:26 AM   #5 (permalink)
SC4Runner's Avatar
No, its an automatic.
Its almost like a vibration noise which is causing this squeeking chirping.
I kept on thinking it was my lower shock bolt squeeking around, but, its something internal. Either from the engine or the transmission... I can now hear a slight "click" behind the squeek. I checked all the body mounts and everything.
It sounds more like the area of the front, but, it could be coming from the back..im not sure....
I had my girlfirend drive it and I stuck my friggin head out the window and I counldnt tell wher eit was coming from hah
__________________
Old 05-31-2005, 11:18 AM   #6 (permalink)
SC4Runner's Avatar
Bump.
It's definetly internal.... coming from behind the engine somewhere near the transmission.
Only happens when I am moving.
Sounds like a loose bolt in my suspension, but, its not. Thats the best description I can give.
I know the timing chain is up front, but, would that be giving this weird chirping sound?
I lubed the driveshafts, still have the noise.
Please help
__________________
Old 05-31-2005, 11:20 AM   #7 (permalink)
SC4Runner's Avatar
Do CV's make any weird noises if they are worn out?
What other things make noises in the front suspension...
1) Lower ball joint? Looks like the lower BJ is leaking out grease
2) Tie rod end?
3) Wheel bearings?
__________________
Old 05-31-2005, 11:26 AM   #8 (permalink)
Quote:
You have a belt on this motor. It is highly unlikely this is the culprit. Have you checked all your drive belts and idler pulley?
Old 05-31-2005, 12:46 PM   #9 (permalink)
bflooks's Avatar
if you are talking about an intermittent slow rattle/not exactly squeek/irritating as all hell sound, then i have it. only i have a 5spd with the 4cyl. 98 runner. it started about a month ago, and only at speeds up to about 35mph do i hear it. so...what is it? haha
bflooks is offline
Old 05-31-2005, 01:56 PM   #10 (permalink)
SC4Runner's Avatar
How do I check the idler pulley and belts? I know to look for cracks, but, do you mean if they are loose?
__________________
Old 05-31-2005, 02:38 PM   #11 (permalink)
The idler pulley will have to be checked with the belt off. That is actually a pretty easy check from accessing it from the bottom. And with a rig with that much lift, it should be cake. Once you get the belt off, you can spin it by hand and check from sound/binding. It should not wobble if you grab it and move it back and forth.
As for the belts, I am speaking mainly of proper tension. I have never used a gauge on my belts, and never had a problem. You should be able to do this by hand. Check the belts after the pulley.
Old 05-31-2005, 02:56 PM   #12 (permalink)
SC4Runner's Avatar
Hmm okay, sounds good. Good learning experience because Ive never touched my belts before
Just have to look in my chiltons manual and check to see which the idler pulley is and how to get the belt off lol.
__________________
Old 06-03-2005, 02:53 PM   #13 (permalink)
TechWrench's Avatar
From the first description, I doubt it is an engine belt. If it was, you would get the noise without the vehicle moving. I think you may still have a u-joint problem. If the joint is bad enough, lubrication will not stop the noise.
__________________
TechWrench
If it ain't broke,
fix it till it is.
'03 SR5 V6, Titanium, 275/70-16 REVO's on '02 OEM alloys for winter. Anti-chipmunk mod for fresh air intake.
TechWrench is offline
Old 06-03-2005, 03:31 PM   #14 (permalink)
Quote:
I agree if that is the case. However, I had a hard time figuring out if it was only while moving. Probably just me reading too fast.
Old 06-06-2005, 12:28 PM   #15 (permalink)
Mad Chemist's Avatar
I assume if you put the brakes on while still pushing the gas (to maintain speed) that the squeeking doesn't go away- this would rule out a brake pad issue.
__________________
-David
'98 4Runner: SAW/OME lift, TJM bumper, Warn M8000 winch, Hayden tranny cooler, Trail Carnage front and belly skid plates, PIAA fogs, Rock lights, 33" MT's on Tech1 Rockcrawler rims, Lars sway bar discos, Sonoran bumpstops and rear bumper, RB 1" body lift, Daystar front bumpstops
'73 FJ40: 327 SBC, York, Dual Batteries, custom tire carrier, Corbeau Baja SS bucket seats, Bestop top.
TLCA#14428
Mad Chemist is offline
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Squeeking that STOPS when I hit the brakes Biohazard General Vehicle Related Topics (Non Year Related) 10 02-16-2007 10:07 AM
Squeeking when driving and window BLU CIVIC General Vehicle Related Topics (Non Year Related) 0 07-18-2006 09:42 AM
Squeeking and tapping noise from engine EWAYota 86-95 Trucks & 4Runners 27 05-31-2006 09:24 PM
Front end squeeking...only when coasting SC4Runner 95.5-2004 Tacomas & 96-2002 4Runners 2 03-15-2005 02:20 PM
Brakes Squeeking---HELP! 4xClover 95.5-2004 Tacomas & 96-2002 4Runners 3 09-22-2003 03:10 PM
2009 InternetBrands, Inc.
