Check Engine Code
Old Aug 26, 2004 | 03:17 PM
denet's Avatar
Check Engine Code
My check Engine light went on couple days again. So I used OBD11 scanner and I got these codes.
P0446
EVAP Emission Control Systems Vent Circuit Malf.
P0441
EVAP Emission Control Systems Purge flow fault.
Is this something I can fix myself or should I take it to a shop?
Thanks
Old Aug 27, 2004 | 03:57 AM
MTL_4runner's Avatar
P0446
P0441
Thanks
What year, model and engine is this vehicle?
Need a bit more infor before we can help you...
Old Aug 27, 2004 | 12:58 PM
denet's Avatar
I have a 1996 Toyota 4runner Limited Edition 4WD.
Thank you for your help.
Old Aug 27, 2004 | 01:09 PM
Good Times's Avatar
since you have the codes, you should be able to figure out which part is bad. use the service manual and walk thru the procedure on checking which item has gone bad.
I had a similar evap issue early on and the dealer warrantied the work as it was one of the sensors that went bad. It was definitely something I couldn't do on my own as I didn't want to pay for it.
if this problem is an emissions issue, maybe the dealer might be able to fix it for free (else, pick up the part and do it yourself if you're capable of wrenching).
Good luck
Old Jun 24, 2005 | 10:43 AM
BOSTON4RUNNER's Avatar
check the thread in the regular maint. forums
i may have found a solution
bigjstang
Jun 2, 2025 03:56 PM
icentropy
Sep 16, 2020 02:47 PM
smiley52
Jul 11, 2015 05:16 AM
Jnkml
Jul 6, 2015 01:20 PM
coryc85
Jul 6, 2015 04:07 AM
