Battery or Alternator??
Old 06-03-2005, 10:08 AM
callmekurt's Avatar
I had my interior lights on overnight the other day. Well the next day, my 4r wouldn't start...almost. First turn, it did the clicking and what-not. After some swearing, I tried it again, but a little longer and it just barely turned over. woohoo!!
So I figured, after it was running for a 1/2 or so (trip to work), it'd be fine. Not so, slow start after work. And then the next morning, again almost didn't start - been that way all week.
So is my battery dying or is the alternator not replenishing it?
Help?
thanks,
Kurt
callmekurt is offline
Old 06-03-2005, 10:13 AM
boogyman's Avatar
if you have a sears near you, they'll check both for free
boogyman is offline
Old 06-03-2005, 02:10 PM
95ToyotaPU007's Avatar
i had a similar situation. the altenator probably is charging the battery but it will take a while. what i did was charge the battery overnight with a battery charger. after that no probs.
95ToyotaPU007 is offline
Old 06-03-2005, 05:21 PM
L33T35T 4Runner's Avatar
sounds like its a dead battery. standard car batteries arent meant to be drained all the way, deep cycle batteries are. car batteries are a shallow cycle battery, meaning its meant to be cranked and recharged over and over again. draining a batter entirely once or twice can be enough to destroy a battery
L33T35T 4Runner is offline
Old 06-03-2005, 08:57 PM
Del
Del's Avatar
+1 for the battery. If it was the alternator three of the warning lights would come on... I think they're the: Brake! light, Check Engine light and Battery light.
Del is offline
Old 06-06-2005, 05:33 PM
callmekurt's Avatar
Update - I think it's the battery (oem). I had it jumped once and charged once by Pep Boys and it won't keep the charge even after 30+ minute driving stints.
And it's still doing the clicking and just barely turning over.
So I figure a new battery, right? If so, any suggestions on a good replacement for 99 highlander?
If there are other things I should do to double-check the problem, please lemme know.
thanks!
kurt
Old 06-06-2005, 10:37 PM
gman72's Avatar
On a '99 Highlander? Seriously doubt it'd be the alternator. Just have the battery replaced with a decent warranty one ... I just brought my battery back to Kragen w/o a receipt after 5 years and they still gave me a couple year pro-rated discount on a new one since the battery had their name on it (and yeah, it was bad ...)
gman72 is offline
Old 06-07-2005, 01:30 PM
callmekurt's Avatar
Yep - it was the battery - the stealer wanted $130 installed. I went to Pep Boys - $70 and I put it in in the parking lot - all good.
kawazx636
10-06-2021 03:03 PM
Obmi
10-04-2015 11:30 AM
bradahman
10-01-2015 09:24 AM
JPV
09-28-2015 03:15 PM
Rcbc92
09-26-2015 03:00 PM
Quick Reply: Battery or Alternator??
