atf recommendations please
Old 09-19-2003, 06:24 AM
dallas tacoma's Avatar
Question atf recommendations please
hi all,
i'm a noob ...been reading and searching this forum for the pass month...Gadgets write up on flushing the auto trans fluids is great seems really simple.
my dad has a 00 tacoma 4wd. Can I use valvoline dextron as oppose going to the dealer and getting the $4 dollar quarts?
Do you guys/gals recommend this?
From what i've been reading many of you prefer amsoil. But I really don't want to spend that much as the car does not really do heavy towing or offroading much...
Let me know thanks!
dallas tacoma is offline
Old 09-19-2003, 07:14 AM
amorphous's Avatar
i haven't done it YET....
Haven't flushed YET....but when I do I'm going to Mobil ATF.
a
amorphous is offline
Old 09-19-2003, 11:11 AM
Robinhood150's Avatar
I think any dex3 tranny fluid is ok. You don't have to go to synthetic, but it doesn't hurt. I wouldn't get the fluid from the dealer though, way too expensive. It's not like there's anything special about it.
Robinhood150 is offline
Old 09-19-2003, 09:03 PM
Toyo4x4's Avatar
Considering synthetic can go twice as long the price is a wash, almost. The tranny will run cooler, too and as you probably know, heat kills. Overkill?...maybe. But its a $20,000+ truck that you probably want to give the best maintenance possible. If I had to do it all over again...I would have gone 100% synthetic after the first 1000 miles.
Toyo4x4 is offline
Old 09-20-2003, 08:27 AM
hmmm...i guess it would not be too late to go synthetic????
the truck has 50k miles on it. would it be to late to go with synthetic?
thanks
Old 09-20-2003, 09:12 AM
Toyo4x4's Avatar
No problem. I switched @ 116K .
Toyo4x4 is offline
Old 09-21-2003, 03:22 PM
Victor's Avatar
Valvoline synthetic is available at Checker/Schucks. Made my power steering a lot quieter and smoother.
Victor is offline
Old 09-22-2003, 05:56 AM
thanks all!! i did the whole flush this weekend, rather simple but a little messy...i must say the first 4 quarts out of the line were a little discolored. but after using 19 quarts it became really clean thanks for the tips!!! i ended up using maxlife dex3.
Old 09-22-2003, 06:12 AM
amorphous's Avatar
flush
hey man,
what's the details....I need to do mine b4 winter.....do you just keep adding fluid till it's clean? got a link?
thanx!
aaron
Old 09-22-2003, 09:41 AM
tomstin's Avatar
Here is a good start http://www.amsoil.com/faqs/faq8.htm I used a 5 gallon bucket, made up a dip stick to track how much came out versus poured in. Had to stop twice to catch up. You don't want to run the pumps dry. The steel line nearest the front on the A/T is the output, follow that to the radiator cooler and disconnect the output from the cooler (driver side on my tacoma). I make up a plug (piece of hose with a bolt in it) for the return. Place the hose in the bucket, and start it up Figure on using about 18 - 20 quarts of ATF to make the flush.
tomstin is offline
Davebarbier
11-03-2015 03:28 PM
Kamaloha
10-16-2015 05:13 PM
1985 4Runner
09-30-2015 10:17 AM
taraf
09-25-2015 02:57 PM
4Xtruck
16
09-24-2015 09:38 AM
Quick Reply: atf recommendations please
