YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > Maintenance & Repair Archives
Home Photo Gallery Register Search Today's Posts Mark Forums Read Tread Lightly Wiki
Thread Tools Search this Thread Display Modes
Old 04-24-2005, 06:18 PM   #1 (permalink)
pruney81's Avatar
86 22re Fan clutch replacement
Does anyone have any tips on how to replace a fan clutch in an 86 4runner?
pruney81 is offline
Sponsored Links
To remove this ad, register today!
Old 04-25-2005, 12:07 AM   #2 (permalink)
Yeah, its easy . Unbolt the 4 bolt's on the water pump and the 3 for the fan shroud and lift them out as 1 piece. The 4 bolts are kinda tricky to get to and to make them easier to get to I would bump the starter to get the bolts where they were easiest to reach. To makes it easier I took off the top radiator hose as well.
__________________
91 Plymouth Laser Turbo-Stock engine all bolt ons
"8AV8"
85 4runner SR5-New project.
Poopy is offline
Old 04-25-2005, 09:10 AM   #3 (permalink)
wimpywade94's Avatar
or just get a 19mm socket on a breaker bar and turn the crank so you can get to each bolt easily with a 10mm open end wrench, the fun part is getting them back on!
wade
__________________
86 runner, rebuilt motor, egr block off, headman header, 3"bl, 33x12.5 m/t's. Lots of work wanted to do. limited skills, funds, time and drive.
If you dont know where your going, anyplace will do.....
wimpywade94 is offline
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Fan Clutch Replacement? the"RoadRunner" 86-95 Trucks & 4Runners 16 12-22-2006 03:57 PM
Solid fan and remove fan clutch?? riceburner 84-85 Trucks & 4Runners 7 07-09-2006 06:55 PM
fan clutch... ksig4runner 95.5-2004 Tacomas & 96-2002 4Runners 6 08-06-2004 02:23 PM
Fan Clutch replacement??? Yoter Maintenance & Repair Archives 3 08-16-2003 01:49 PM
Powered by vBulletin® Version 3.6.4
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
2002-2008 Yotatech.com
