| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
Swaps that work with 4x4 IFS and stock height
#2 (permalink) |
Lc engineering has a sweet second gen with a 3rz in it. I wonder how hard that would be since its a 4cyl also...
#3 (permalink) |
i heard the supra straight 6 turbo bolts directly onto the 22re motor mounts... i dont know for sure, but... yeah.
__________________
The 22r series engines are made from the fires of hell, and will fight tooth and nail to not be sent back. 1988 Toyota P/U 4x4 22re, 1200 miles on the rebuild engine builder .268 cam pioneer CD deck 31x10.50x15 BFG A/T BAJA 100W lights on prerunner bumper KC Daylighters 100W rancho rs5000 MUD IS A VALID PAINT JOB! If not living life to the fullest, why live it? my trucks official buildup thread |
#4 (permalink) |
Yea the supra motor bolts on when using the 5m mounts, but there is no concrete info on whether or not it works with the oil pan. I've heard about using the cressida oil pan and that it's center sump or something instead of front but I was just wondering if anyone has swapped in a motor and kept it IFS.
#5 (permalink) |
Don't know how much this helps, but I just met this guy with an '84 Xtracab:
http://blazeland.us/Home_Page.php that has a 5.0 he said he swapped in about 10 years ago. It has a body lift and the long travel kit mentioned in the website, but it is still IFS and a 5 speed.
__________________
"If it's worth doing, it's worth doing right" my father-in-law 1989 4wd Xtra Cab, 3.4L V6 A340F auto, gear drive transfer case, 3" Downey rear leafs, 1.5" BJ spacers, Doetsch Tech shocks front & rear, E-code Hellas 4.88 gears, ARB locked F&R, Toyo Open Country MT 255/85R/16, Procomp 16x8 black steel Krawlers Badlands Basher front bumper, Warn M8000 winch, All-Pro Off-Road rear Tacoma bumper Revenge Fabrication Sliders Alpine CDA 9857 My 3.4 swap |
#6 (permalink) |
There are a few on here with the supra swap and many others with the 3.4. They seem to be the most frequently used. Dont even consider the 3.0 (not much gain over the the 22RE). Search and you will find many good threads with the info you need.
#7 (permalink) |
Banned 'cause I was 4runnerchevy also banned
If you want an IFS with Supra 5m or 7m, I'll hook you up. Its not easy, but workable.
#8 (permalink) |
I am the guy (or mabey just another guy) with the 5.0 swap from a Mustang. My truck is a 1986 xtracab DX 4x4. I do have the IFS and it is "long travel" of my own design; the Blazeland LT. Advanced Adaptors made the motor swap kit. I dropped the front diff 1.5" to clear oil the pan. But, oil pan could be modified fairly easily; rather than dropping the diff. I am using the T-5 five speed manual transmission from the Mustang. Where did we meet?
#9 (permalink) |
I met you at Pep Boys in Lake Forest. I have the grey XtraCab with the 3.4 swap. That was a typo in the post, I meant '86.
__________________
#10 (permalink) |
I too have 5.0L, IFS, and no body lift. It's tight but can be done. I modified my oil pan because I wanted the engine to site as low as possible, keeping the cog low, since I also have long travel and do a lot of high speed stuff in the dez. I spaced the front diff down a little so that it was flush with the crossmember in front of it. I mated a Ford AOD tranny to a w56 TC, with an Advance Adapter kit
Posey
__________________
88 4Runner, 5.0L EFI, AOD, W56 T-Case, Total Chaos Gen II IFS, King coilovers in front, King shocks in rear, 63" Chevy rear springs, 33" BFG mud's, Lock-Rite in front, Detroit Tru-trac in rear www.LocosMocos.com |
#11 (permalink) |
Well I finally got around to doing the oil pan modification. The front diff was dragging all over the place. When the suspension compressed it was only about 3" off the ground and would high center fairly easily. With oil pan modification I am back to the stock mounting points and front crossmember. I probably only added around 2" of additional clearance but every little bit helps. Here are a few photos.
#12 (permalink) |
Looks real similar to mine. Looks good!
Posey
__________________
#13 (permalink) |
Yeah, its not rocket science but thought I'd post pictures in case others out there were interested in a visual. I did have to bend the oil pickup tube slightly so it didn't hit the patch.
Hey what spring rate are you using on the front coils? I had a 700 lb spring but it was too stiff. I tried a 550 and it was too light. I am now using SAW 25mm T-bars with very little preload and it works great. I am running the wwwblazeland.us long travel kit now so I have T-bar as well as coil conversion options, have you checked blazeland out? FYI the 550 lb coil springs are about right for my 4 Runner but it still has a 22RE. Although its a little bit heavier the Ford 5.0 power is awsome isn't it? The AOD must be nice for crawling. |
#14 (permalink) |
I think I took a little more out of my pan. I lowered the front diff until it was flush with the crossmember and then worked to set the V8 engine in there as low as possible. I actually made a divorced pickup for my oilpan. The pickup is welded to the pan and a hose is used between the pump and pickup.
Not 100% sure about the spring rate. I just talked to the guys at King, explaining my setup, and they picked the spring rate and shock dampening. I can check them the next time I'm at the shop. The V8 was not much heavier, if any, than my original 3.0 V6. The AOD is great and is the real reason for the V8. I wanted to run an automatic, but the V6 with an Auto was a dog, so the V6 had to go. I see you are in SoCal. You familiar with Locosmocos? A lot of those guys are located around Lakeside. That's my gang! Posey
__________________
#15 (permalink) |
Wow, the oil pan you came up with sounds interesting. I didn't locate my engine, I just bought motor mounts for the swap from Northwest Offroad. I did have to install a 2" body lift to clear the tranny. Sounds like you C.G. is much nicer.
I ran into the Locosmocos guys a few years ago in San Felipe pre-running the Baja 250. I was in my 4 Runner and stopped and talked a bit. I had the Blazeland LT on the 4 Runner and they looked at it but didn't seem to interested. I am going to San Felipe again this year and would love to meet up. Do you go? Last edited by BlazeN8; 11-11-2009 at 10:15 AM. |
| Tags |
| 22re, 4x4, 88, blazeland, fab, height, ifs, lift, long, motor, ride, stock, supra, toyota, travel, work |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Needs pics of stock 4x4 4runner IFS | mlrtime99 | 86-95 Trucks & 4Runners | 22 | 09-30-2008 01:07 PM |
| Stock IFS height? | Matt16 | 86-95 Trucks & 4Runners | 2 | 09-30-2008 10:17 AM |
| 265/70r16 on stock height stock geared 22re | 943kgt | 86-95 Trucks & 4Runners | 5 | 08-31-2008 02:43 PM |
| what is the stock ride height on an 88 4x4 pickup? | nreno88 | 86-95 Trucks & 4Runners | 12 | 01-08-2006 05:35 PM |
| biggest tires width/height stock height | phat4rnr | 95.5-2004 Tacomas & 96-2002 4Runners | 16 | 07-19-2003 12:20 PM |
