Motor swap help??? - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Off Road Tech, Fab Shop, Solid Axle Swaps, Tool Time, & Engine Swaps > Engine Swap Talk > Engine Swaps
Welcome to Yotatech!
Welcome to Yotatech,
Old 10-18-2009, 07:50 PM   #1 (permalink)
Motor swap help???
What's up guys? Hey I am new to the toyota world and recently got a 94 4runner on a trade. The 4runner is very clean but it is a 3.0 V6 with an auto tranny. It seems to run fine has new gaskets and water pump and all that stuff. I want to know if you guys think I should swap out the motor or just put a 5 speed in it. I use it for going off road but don't like the auto and have heard lot's of bad stuff about the 3.slow as some would say. I know a lot of people are doing the 3.4 liter swap but seems kinda spendy. Could you guys give me some info and maybe advice I guess about what motor I should go with? Also I am wanting to level out the rear and was thinking either the FJ C rear coils or the OME rear springs. If I do this can I just put the coils in or do I need to do other things too? Thank you guys for any help at all.
fullyboostin is offline
Old 10-18-2009, 08:08 PM   #2 (permalink)
myyota's Avatar
The 3.4 is the most popular swap for the 3.slow, but some others here have used other engines like a 7MGE, but either way the swap is expensive. If you really want to do a swap just start collecting the parts needed a little at a time until you have everything you need to start the swap.
__________________
86 Toyota 4Runner
Solid Axle Swap, 16'' of lift, 37x12.50-15 GoodYear MTR tires, 5 speed manual trans swap, InchWorm Duel Cases With 5.7 Gears, 63'' Chevy Springs In The Rear, 5'' Trail Gear Springs In Front, Marlin Crawler Third Members, 4.88 Gears With A Detroit In The Rear, High Pinion Front With 4.88 Gears And An ARB, Downey Header, Optima Battery, Trail Gear Sliders, Addicted Offroad Front Bumper, Trail Gear Rear Bumper.
myyota is offline
Old 10-18-2009, 10:54 PM   #3 (permalink)
whokrz's Avatar
Some people are also doing a 1uzfe (lexus v8) swap.
For any swap I would recommend getting a wrecked vehicle that has the engine that you want, still has a intact engine bay with a running engine. This way you will have all of the efi components you will need for the swap, and you will know that the engine you are putting in ran correctly before the swap.
__________________
1990 4runner, 22re, R151, 4.7, 5.29s, E-locker front, Lock-Rite rear, 37" MTRs, 51" rears all around
Trail Reviews http://www.gentryoffroad.com
Toyota Factory Service Manuals http://ncttora.com/fsm/index.html
whokrz is offline
Old 10-18-2009, 11:16 PM   #4 (permalink)
So roughly could you guys give me a figure on price minus the motor. Also I read you have to use parts from the 3.0. Can you guys tell me more about this or send me a link to a past post. I'm sure there has to be one lol. I really appreciate the help guys.
Old 10-19-2009, 09:29 PM   #5 (permalink)
whokrz's Avatar
Engine Swap Talk on yotatech.
http://www.yotatech.com/f159/
__________________
whokrz is offline
Old 10-19-2009, 11:14 PM   #6 (permalink)
Thank you very much for that. Any info on the rear spring swap?
Old 10-20-2009, 05:27 PM   #7 (permalink)
whokrz's Avatar
I used HD ome coils in my 97 and was very happy with them. I could load it down with weight and it still didn't sag. The rear springs for a 94 may be different but the suspension is coil spring on both vehicles.
http://www.gentryoffroad.com/php/gen...uctreview/ome/
__________________
whokrz is offline
Old 10-20-2009, 06:40 PM   #8 (permalink)
Tragic Drive's Avatar
Quote:
The cruiser springs will boost the rear about 4 inches. Unless your going to lift the front I would go with OME springs.
I've been driving my Runner with just the cruiser springs for a a few years now.
Honestly, the caster on the front end alignment is kinda sketchy.
I'm told that the ball joint spacers that I have will correct this though.
I just haven't put em on yet.
Good luck.
__________________
,Thomas
Supercharged 3.4 in a ARB Locked 95 Runner
Tragic Drive is online now
Old 10-20-2009, 07:41 PM   #9 (permalink)
So if I go with just the OME heavy duty 1.5 inch rear springs to level it out can I just swap the springs or do I have to change other things too?
Old 10-20-2009, 09:26 PM   #10 (permalink)
RobD's Avatar
I have the medium rate Old Man Emus and love them. They level out the ride height, allow you to full load with minimal sag, and ride nicely when unladen.
All in all, a good choice.
__________________
1991 4Runner, 3.4 5VZFE swap, OME shocks/springs, 33" BFG All Terrain T/A KOs, Pioneer head unit, Infinity speakers, XM Satellite radio
RobD is offline
Old 10-21-2009, 12:04 AM   #11 (permalink)
So were you able to just buy the springs and put them in with out any other parts?
Old 10-21-2009, 11:21 AM   #12 (permalink)
anthony1's Avatar
Send a message via AIM to anthony1 Send a message via Yahoo to anthony1
Nope. You gonna need to level the pan hard rod, raised the proportioning valve and extend the brake line. If you don't do those things, your truck rear axle will not lined up with the frame and you won't have much rear brakes.
__________________
http://www.angelfire.com/ca6/954runner
GOD's Country Best Seen In A 4 Runner. SAS front: lf,ARB,Ml4",Marlin arms, rear: cable elock,APlinks,OEmu860,35MT/R 5spd, 4:1.
..."But officer, that was not an illegal turn, it was just an undocumented turn."
anthony1 is offline
Old 10-21-2009, 12:02 PM   #13 (permalink)
hello. hope im not repeating something. im doing a swap right now. but i have the 3.0 engine and am putting a new 3.0 engine back in. sounds stupid. but i got it for a good price and very low miles. is there anything special about taking out the engine ? like special tools or procedures.
danavanhuber is offline
Old 10-21-2009, 01:57 PM   #14 (permalink)
So is there like a kit I can buy or can you tell me what I would need. I really hate this sag.
Old 10-21-2009, 02:03 PM   #15 (permalink)
theAuthority's Avatar
CLICK ME .........
__________________
Proud sponsor of the re-poster thread. Where there is Substance.
http://www.yotatech.com/f5/you-re-poster-193103/
theAuthority is offline
Old 10-21-2009, 02:45 PM   #16 (permalink)
that must be for the other dude.
Old 10-21-2009, 05:53 PM   #17 (permalink)
whokrz's Avatar
Quote:
In my sig there is a a link to Factory Service manuals.
__________________
whokrz is offline
Old 10-21-2009, 06:05 PM   #18 (permalink)
whokrz's Avatar
When I did 2.5 inch ome lift I did not level the pan hard or raise the portioning valve. I could not tell that the rear axle was to one side. I understand the geometry but didn't see the need. I also found that the braking was still not bad, and the rears would still lock up if I pushed hard enough on the pedal. Other people however have had different results in braking and handling, also the braking system may be larger on a 97.
I did use a extended brake line because I went with longer shocks. I made my own brake line bracket out of 3" x 1" x 1/8". I drill two holes and used a scrap bolt and nut.
__________________
whokrz is offline
Old 10-21-2009, 08:37 PM   #19 (permalink)
So is there somewhere I can get the brake line the new plate to move the valve and a kit to level out the pan hard
Old 10-21-2009, 09:18 PM   #20 (permalink)
If your going to use the OME 1.5 springs to level it out you shouldn't need any thing else.
__________________
,Thomas
Old 10-21-2009, 09:19 PM   #21 (permalink)
whokrz's Avatar
I got my stuff from http://www.wheelersoffroad.com/
Here is a thread on here about where people bought theirs.
http://www.yotatech.com/f2/old-man-emu-where-buy-10482/
__________________
whokrz is offline
Tags
30, 31, 34, 4runner, 95, engine, motor, price, rear, swap, toyota, whats
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
2009 InternetBrands, Inc.
