Engine Swaps Swapping an engine in your Toy, here is where to learn how
91 tranny and 3.0 7mge
Old 06-10-2010, 02:45 PM
chevyguy-trapped's Avatar
can anyone tell me were to get a bellhousing adapter plate to go from a 91 4x4 tranny to a supra 7mge motor?
Old 06-10-2010, 02:50 PM
2DoorRunner's Avatar
if its a 5spd use the bell housing from an 89 or older supra. The supra tranny is a w series so i will bolt right up.
Old 06-10-2010, 02:52 PM
Here is proof
"The write-ups above go through the actual install fairly well, so I’ll try to avoid repeating too much. What you’ll need to get the 7MGE bolted in:
- Supra bellhousing, clutch fork & throwout bearing retaining spring, clutch slave cylinder & hose - Supra’s used a “W” series transmission which uses the same bellhousing-trans bolt pattern as the “W” series truck trans – you will use your stock “W” series trans and transfer case – use a pre ’89 bellhousing, after this Toyota changed the clutch and pressure plate design, pre ’89 is the standard “fork and throwout” style"
And his swap thread...
https://www.yotatech.com/forums/f161...-supra-162638/
BeMiceElf
10-10-2015 09:40 PM
squiggypowell
08-19-2015 03:07 PM
norcal98
08-10-2015 06:20 AM
exporunner
3.4 Swaps
08-03-2015 06:10 PM
Iceman4193
07-15-2015 04:48 PM
Quick Reply: 91 tranny and 3.0 7mge
