YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Off Road Tech, Fab Shop, Solid Axle Swaps, Tool Time, & Engine Swaps > Engine Swap Talk > Engine Swaps
Home Photo Gallery Register Search Today's Posts Mark Forums Read Tread Lightly Wiki
Thread Tools Search this Thread Display Modes
Old 05-09-2008, 06:14 AM   #1 (permalink)
85 ext cab with 350 needs some help
Hey all, I'm new to this board. I usually post over on ttora and lurk here, but this board has more 350 swap activity so I thought I'd run this past you all.
I recently picked up an 85 ext cab that had a 350 swap done. It already has a hacked 3" body lift (alum spacers and rubber tire sidewalls for cushion) and a mis matched rancho + other suspension lift.
When I drove it home, it was running really hot, tho the aftermarket temp gauge in the cab didn't work, so I don't know how hot. I started reading/researching the swap and it seems that the motor is mounted pretty far forward. There is about 3" behind the distributor and about 1/2" between the front pulley (short neck water pump) and the radiator (4 core brass/copper), barely enough to get the pulley bolts out. Also a no-name fan in front pushing air.
Besides this, there was some funky brackets for the toy P/S pump and alt that were misaligned. I started by pulling the brackets off (bolted directly to the water pump) to straighten them, and since I was there, I went ahead and pulled the thermostat (190*), water pump (for inspection) which lead to pulling the radiator (couldn't get the water pump off due to space).
My question is should I just try messing with re-fabricating the core support to fit a ford taurus fan and better radiator? or actually pull the motor and move the mounts back so I have some room up front?
I plan on putting an NV4500 tranny with a dana 300 t-case in it (both heavy and short) so I'm thinking that pushing the motor back would help with weight distribution as well as providing room for proper cooling.
After it runs/cools better, I need to tackle the suspension.
Also, when I had the thermostat out, I swaped in an 180* unit in hopes of getting the circulation started earlier.
mrdoug is offline
Sponsored Links
To remove this ad, register today!
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
92 Toyota Ext Cab: KS 1320ft Vehicles - Trailers (Complete) 9 01-13-2008 04:31 PM
single cab and ext. cab doors?? david28 86-95 Trucks & 4Runners 7 04-15-2007 03:36 PM
parting 84 and 85 EXT CAB insane04 Misc Stuff (Vehicle Related) 18 01-18-2007 10:44 AM
Easiest way to convert Std. Cab to Ext. Cab? EWAYota 86-95 Trucks & 4Runners 24 08-25-2006 09:14 AM
Powered by vBulletin® Version 3.6.4
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
2002-2008 Yotatech.com
