5.0L vs. 3.4L
5.0L vs. 3.4L
So I am at a cross roads on what to do with the motor in my truck. Both engines can be had for roughly the same price. I know the 5L is going to be alot more work, but is it worth that work? There are plenty more power upgrade options for the 302 and they are much cheaper. What's everyone's insight?
First off- you need to be realistic about what power levels you WANT, and what your truck can handle. Sure- a 5.0 has alot more available for it, but what good is a 347 w/450 hp if it spends it's life down at 2-3K rpm all day?
Just for comparison, I dyno'd my supercharged 3.4 that has a few additional power-parts, 252 rwhp first time out, with a bad coil! I then replaced the coil, and refined the A/F ratio a bit more- bam! 306 rwhp, on a stock pulley. I went this route because there was very litte fab needed, and I didn't lose any of the rest of the vehicle's functionality- and I like OBD II diagnostics.
Either way- good luck!
im not badmouthing your set up (hell i want one) but 300+rwhp just isnt going to happen with a 3.4 without many mods...
theres a big difference from 300hp at the crank to 300hp at the wheels.
either way, a finely tuned s.c. engine (with perhaps an upgraded turbo) can easily attain 300hp at the crank.
_+ he did say "my supercharged 3.4 that has a few additional power-parts"
but back to the thread.
at any rate, i would consider the maintenance costs w/the 2 different engines.
long run, what will be more cost effective (considering the fuel crisis)?
im interested in this thread also. to see who/how others have done.
Both seem to be very reliable motors. The supercharged 3.4 may close the power gap on the 5L but then reliability comes into play, having to run premium ect. Also, normally domestic parts are cheaper than import.
On the other side there is the ease of installation, no need for adapter plates, new motor mounts, gauges, alternators, ect.
I dont need the 300hp, but a local guy that is running a 5L says he gets better mileage now compared to his 3.0 because the motor does not need to work as hard to push his rig. I can see that statement being true, also the V8 has the torque curve starting lower.
Oil is going to break $100 a bbl very soon. meaning $3.40 to $3.60 a gal or therebouts depending on where you live.
1. I didn't mean to 'own' anything; I'm obviously biased toward the 3.4 having done my own rig that way. I also strive to keep things lighter when I can. It's the same reason why I put a turbocharged 4.2 Trailblazer engine in my 68 Firebird.
2. Sorry if you don't like the #s, but it's a reality. Stock longblock- SC, 325cc injectors, Walbro 190 FP, Supra MAF, modified Downey headers, stock pulley pushing 6-7psi, my own intake tube, FTC-1, IK22's, Innovative WB for tuning, 3" exhaust, Snow water injection. This through a MC clutch, a fresh R151F, 4.56 (w/ synth) gears, on 31" tires. Wait till my purpose-built block & heads go in! If it helps you at all- I do beta testing for some of the aftermarket EFI systems, so I kinda know what I'm doing.
3. Yep- yer right, MANY 5.0's are OBD II; if he swaps over the ECM. My bad- most of the swaps I see are carbureted or TBI setups.
Jeff
PS- GREG_CANADA, that is a sweet 89; I miss mine...
Jeff
think about how much fun having a v8 in your toyota will be. the 3.4 will be more reliable, but the 5.0 is a much more common engine, if i ever have the $$ to spare i would want to do a 5.0 swap, all that torque of the v8 just makes me drool
unless you want to keep it toyota you might as well go for the v8 if your going to go through all the trouble to do the swap. i dont know about gas mileage and how that will come out but i never thought of my truck as an economical ride, but thats why i got a bike
But as for your engine dilemma, I'd recommend a Buick 3.8. They are light, very reliable motors, and have a very nice, and usable powerband. They are also nice because some of them are factory supercharged, and the engines can be had pretty inexpensively, in quite a few cases, under $1000 for a used one. But that's if you know where to look, and where you live, too.
Jeff
Jeff
I've been thinking of a blown 5vzfe for awhile.. .still deciding on a custom turbo or the trd blower... what do you think? i dont need this thing in the 12's.. but a mid 14 second truck with 33's would be killer... (considering its a high 17 mid 18 now)...
btw thanks on teh truck.. i have the bumper painted and lights on it now....
http://s148.photobucket.com/albums/s35/Greg_Canada/ look here for more pics if you'd like.
How tough was the 5vzfe supercharged swap? did you use the ORS harness?
What was the A/F ratio running at for that?
You ever dyno yours MT?
Whats your acceleration like compared to the 3.slow? (like what car would you compare it with)
i prettymuch want a sweet 25-70mph accel... highway onramps... my buddys jetta vr6 pulls nice.. .i'd be happy with mine like that...
I know TRDOLMAN had dyno numbers over 300 RWHP on his 5VZFE but he told me that was with a 2.0" pulley. He also was running no cats, headers and IIRC he was running a little on the lean side too (like around 13).
You might hit up www.rockstomper.com. Scott Ellinger had a 5.0 in his truck years back. It had it's good and bad points. Weight is one of the bigger bad points. It breaks stuff on the trail especially when combined with all the added torque.
I would take a "systems level" approach to selecting your engine. If you don't wheel hard, well you can get away with more engine Vs. breakage. If you do, you might find you are now stressing, or example, steering parts and end up rebuilding and reinforcing a lot more of your truck then you would if you went with a lighter engine.
Frank
Read this article...http://toyota.off-road.com/toyota/ar....jsp?id=305949
It will show you a lot about what you might encounter with V8 power under the hood.
Frank
Frank
That's a bad link Frank, I think it has too many https.
In addition to the weight I wouldn't like the extra size. Seems to be a very tight sqeeze to get a V8 in there and still have room for a radiator and fan.
I fixed it. Yeah I wouldn't do this V8. It wrecked his front diff, etc... If one HAS to do a V8, look at the newer lower displacement engines which are still quite powerful while being lighter. There will likely be some CAN issues to work out but a smart shop can help there.
Otherwise, go with the V6. I mean you really need to think about how much power you need Vs. want and more is not always better. In 4low you hardly need any torque to crawl. The power is really to improve street driving maybe also help you in the sand/mud if that's your thing. Even then you don't need 4 million horsepower.
Frank
Frank
