22RTE swap complete WILL NOT STAY RUNNING - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Off Road Tech, Fab Shop, Solid Axle Swaps, Tool Time, & Engine Swaps > Engine Swap Talk > Engine Swaps
Welcome to Yotatech!
Welcome to Yotatech,
Old 04-21-2008, 08:57 PM   #1 (permalink)
Thumbs down 22RTE swap complete WILL NOT STAY RUNNING
Just got through completeing 22rte swap into the 88 runner and she will fire but won't stay running. Have not had a chance to do fuel pressure check yet but the pump is running. The truck sat for 3 years with no fuel in the system. The swap was taken out by me and installed by me. Now there were some wiring issues that I am still sorting out but as far as I know there should't be anything holding this thing back from running. I am getting code 23 which is intake air temp signal and also 28 which is 02 signal but like I said neither of these should give me any hurdles. Any help is greatly appreciated.
Ok updated flipped the distributor 180 degrees truck will now idle. The truck will not rev up past say 2k. I checked for vacuum leaks etc. I really think that I am missing something from the other truck. I have what appears to be a map sensor that I took off of the other truck has 3 wires from it and a vacuum line. The other truck is gone so I can't go back and check it. seems as if when the truck goes into boost than this would take over and that may be my problem.
92laser is offline
Old 04-21-2008, 09:11 PM   #2 (permalink)
TOYOTA 1's Avatar
this might sound dumb but... is the maf sensor plugged in?
__________________
91 Toyota "built not bought"
Quote:
Originally Posted by BigBluePile View Post
I just bought a Toyota and I don't have any tools or any kind of area to work on it with and I'm wanting to drop in a V8 and clear 38's but I don't have any money and do I need to lift this if so what kind of lift and what do you recommend also I'm not sure if all terrains will work in mud is there another kind I have some rims that should work but they came off a yugo so is the bolt pattern the same...
TOYOTA 1 is offline
Old 04-22-2008, 06:09 AM   #3 (permalink)
Yeah its plugged in. I drove the doner into the shop to do the swap and my truck ran before i took it apart. However my truck was down for 3 years. I am gonna run a can of toyota fuel injector flush through it today and see if it runs off of that. Hell the pump may be bad or may even have some trash in the line. Any other ideas on this.
92laser is offline
Old 04-23-2008, 11:24 AM   #4 (permalink)
Still nothing will not even run off of a fuel injection can. Anybody, no takes on this. Does anybody have access to a turbo truck that they can snap some pics of some areas for me. left and right engine side of fenders and the firewall to verify all my stuff is hooked up correctly.
Come on guys I am ready to drive this beast. I am gonna make my 3inch down pipe and exhaust tonight so lets help me get this thing rollin
92laser is offline
Old 09-08-2008, 07:31 PM   #5 (permalink)
im swapping a 22rte into my 88 right now ill let you know of any problems i encounter maybe we can help each other
crimsonking32 is offline
Old 09-08-2008, 07:41 PM   #6 (permalink)
ozziesironmanoffroad's Avatar
Send a message via AIM to ozziesironmanoffroad
try actually driving it... is the turbo spooling?
__________________
The 22r series engines are made from the fires of hell, and will fight tooth and nail to not be sent back.
1988 Toyota P/U 4x4
22re, 1200 miles on the rebuild
engine builder .268 cam
pioneer CD deck
31x10.50x15 BFG A/T
BAJA 100W lights on prerunner bumper
KC Daylighters 100W
rancho rs5000
MUD IS A VALID PAINT JOB!
If not living life to the fullest, why live it?
my trucks official buildup thread
ozziesironmanoffroad is online now
Old 10-30-2008, 02:24 PM   #7 (permalink)
400yzturbo's Avatar
I did the swap from a 22re to a 22ret a few years ago. I just had issues with blowing head gaskets.
Just a thought for you: When you did the swap did you get the turbo computer from the turbo truck to replace you regular ecm? Also make sure you have no leaks from the turbo to the intake. It wont appear as a vacuum leak it will be more of a pressure leak especially under a little boost. If the air line from the turbo has a crack or small leak it will cause it to not run right. With the one I did, my turbo line came off under boost and the truck would barely idle and when you gave it any gas it would die.
This may help it may not.
400yzturbo is offline
Old 11-14-2008, 11:45 AM   #8 (permalink)
92laser do you still want pics of the engine bay? I swapped a turbo 22RE in mine and everything is hooked up correctly. The only things I had to get from the donor truck other than the engine were the computer, airbox, airbox plumbing, and radiator. I can take some pictures if you'd like.
__________________
87 4Runner-Swapped in Turbo 22RE/R151 5 speed, electric fan, high-flow cat, dynomax turbo muffler, lockrights front and rear, 4" Trailmaster front bracket lift, tbars SOFT, sagged rear 3" add-a-leaf, 3" blocks, Skyjacker shocks, 3" body lift, Specialty Top/Kayline Soft Top, Ramsey 8500 winch, homemade front reciever/winch bumper, homemade rear hitch bumper, full size spare, 35x12.5-15 Radial Claws most of the time, 34x9.50-15 TSLs for 0-35" mud bogs, 5.29s
Skinsfan6 is offline
Tags
1986, 22re, 22rte, 4runner, 87, 96, air, box, rev, running, starting, starts, stay, toyota, truck
« engine swap | ecu »
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
96 Tacoma won't stay running Mike Hagstrom 95.5-2004 Tacomas & 96-2002 4Runners 2 01-09-2009 08:13 AM
F/S 22RTE turbo complete engine foxfab The Classifieds GraveYard 1 06-19-2007 02:39 PM
Engine won't stay running 89truck 86-95 Trucks & 4Runners 30 04-07-2007 06:08 AM
Doesn't Stay running??? 943kgt 86-95 Trucks & 4Runners 7 02-04-2007 04:33 PM
3.4L swap wont stay running need HELP!! node 95.5-2004 Tacomas & 96-2002 4Runners 17 03-10-2005 11:45 AM
2009 InternetBrands, Inc.
