what size tires is everyone running
little bit of background info:
I'm planning on doing a sas to my 87 4runner with a 4.3 tbi and i fit 36x12.5 TSLs right now with no lift other than a 3" BL. I'm planning on doing a 3" trail gear sas with chevy leafs out back as i carry a lot of gear with me when i go out.
Question:
whats everyone running for tires size with a 3" sas kit and a 3"BL?
thanks to everyone in advance
Question:
thats all i took out
and they are on 15x10 rims with a 4" backspace so they stick out farrrrrr
Nope that's what 2.5 inches out of a mint fender looks like
I have 6" shackles in the rear to level that sag out
Im runnin 36 13.5 on 17s irocs with chebbis out back out of an 04 two wheeler and the fronts are lifted rears of a 1st gen pick not sure on how much lift they are. i have a 4.3 in mine and the front springs sit down quite a bit and it also moved the front axle forward about 2.5 inchs and no rubbin at full stuff and full turn. also for the rear i had to put a 1in block to level it out
Running 35x16x16.5 boggers. Dana 44 front and Corp 10 bolt rear. Used 3" lift 89 4runner rear leafs up front stretched it 3" and chevy 59" stock leafs in rear with block. Seems to be a good fit....
Did you trim the rear on this runner? If so, can you post a picture of the rear fender?
Yeah i had to re-do my rear quarters because were all rusted out so i stretched the back wheels out a few more inches and made my own quarters out of sheet metal. Trimmed off about 3-4" from stock turned out pretty nice and got rid of that ugly fender flare and bottom bumper piece ...
06-01-2021 01:51 PM
