And so the SAS begins... - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Off Road Tech, Fab Shop, Solid Axle Swaps, Tool Time, & Engine Swaps > Solid Axle Swaps, All Years
Welcome to Yotatech!
Welcome to Yotatech,
Old 07-26-2008, 03:41 PM   #1 (permalink)
pepsibluefloat's Avatar
Send a message via AIM to pepsibluefloat Send a message via MSN to pepsibluefloat Send a message via Yahoo to pepsibluefloat
Well, i decided to make a thread dedicated to my SAS. Now i wont have to start a new thread every time i have a question, ill just post it in here.
I actually started my sas about 6 months ago when i bought the axle. I've been rebuilding it in my barracks room since then. Last week i finally started cutting and put the axle under.
here is what i have so far::
5.29 gears
Aussie Locker up front
Longfield inners, Birfs, and hub gears
Backing plate eliminator kit
vented fj60 rotors
manual aisin hubs
3" trail-gear front springs
marlin crawler high-steer
bilstein's
4" trail gear rear springs
35x12.5 Goodyear Wranglers
15x10 crappy used wheels
lock-right rear locker
__________________
1988 4runner::SAS|3.4L swap|Swap to 5speed manual| RF1A |5.29's|Aussie Front|LockRight Rear|Longfield axles/Hub Gear|4"Rear/3"Front springs|Marlin High Steer|Custom CV rear driveshaft from High Angle Driveline|Rear D/S shortened and made into front D/S |35" Goodyear MT/R | Addicted Offroad front bumper | Marlin rear bumper
My 4runner n stuff
pepsibluefloat is offline
Old 07-26-2008, 03:42 PM   #2 (permalink)
now, i know you are all tired of reading and wanting pictures, so here
BEFORE pictures:
__________________
My 4runner n stuff
Old 07-26-2008, 03:44 PM   #3 (permalink)
And here is the lovely axle how i received it::
__________________
My 4runner n stuff
Old 07-26-2008, 03:46 PM   #4 (permalink)
...and some pictures of rebuild::
__________________
My 4runner n stuff
Old 07-26-2008, 03:49 PM   #5 (permalink)
...and last week i started cutting and put the axle under. I wasnt able to finish all the cutting, but i was at least able to get it drive-able.
And i was hoping to do the rear this weekend, but my rear kit came in yesterday WITHOUT the rear shackle hanger. So i guess i'll be driving around like this for another week, heh.
__________________
My 4runner n stuff
Old 07-26-2008, 03:57 PM   #6 (permalink)
and for my 1st question in here.
My driver side hub is HARD to turn. Even with the wheel on i have to put a little muscle to turn it. It also gets REALLY hot after 10 minutes of driving. The brakes don't seem to be rubbing. Could the bearings be too tight? i torqued them to spec. the same as the other side, and the other side is fine. Will bearings loosen over time?
__________________
My 4runner n stuff
Old 07-27-2008, 05:17 AM   #7 (permalink)
dirtoyboy's Avatar
What did you torque the trunions to? What did you torque the wheel bearings to? Did you measure your wheel bearing pre-load WITHOUT the felts/rubber ring installed? No it shouldnt be that hard to turn.....
__________________
Low down and durrrrrrrty Rock stacking Web Wheeler.
Locked, lifted, trussed, SASsed, triangulated, dual cased, shaved, armored, gusseted, hydro'd, blacked out, crapped out, mashed up, merderrrrrd out and ready to hit the mall!
It's a Jaap thing....You wouldnt understand
Quote:
Originally Posted by SwampThing View Post
Oh, after a consult with Mr. Anheuser, I think I beer-stormed a way to test the gears
dirtoyboy is offline
Old 07-27-2008, 06:38 AM   #8 (permalink)
Super Moderator-Sponsoring Member
Staff
waskillywabbit's Avatar
Send a message via AIM to waskillywabbit Send a message via MSN to waskillywabbit Send a message via Yahoo to waskillywabbit
Did you rebuild the manual hubs? Most of the time they are hard to turn from a bad hub dial o-ring or too much grease.
Best way to tell is take the manual hub off and then see if it is still hard to turn. If not then you got other issues further in the axle.
waskillywabbit is offline
Old 07-27-2008, 06:56 AM   #9 (permalink)
dirtoyboy's Avatar
Oops, I misunderstood...I thought he meant the hub/rotor assembly was hard to turn on the knuckle...my bad..
__________________
Old 07-27-2008, 07:04 AM   #10 (permalink)
Staff
I dunno. The way he says it sounds like it could really be either.
You talking about "manual hub" or "wheel hub" ???
Old 07-27-2008, 07:55 AM   #11 (permalink)
__________________
My 4runner n stuff
Old 07-27-2008, 08:01 AM   #12 (permalink)
Quote:
maybe a dumb question, but whats trunions? And no, i didnt measure the pre-load without felts.
my fault, i meant the wheel hub. And this is the sequence i used for tightening the spindle nuts::
* Torque spindle nut to 43 ft. lbs.
o Spin hub right 4-5 rotations
o Spin hub left 4-5 rotations
* Loosen inner spindle nut
* Torque spindle nut to ~21 ft. lbs.
My passenger side is fine and the ONLY difference is the brand of outer bearing. The driver side is trail-gear, but i couldn't get the trail-gear bearing to fit on the passenger side so ended up having to get another one from autozone. That's why im thkning it must be the bearing isnt right or something?
__________________
My 4runner n stuff
Old 07-27-2008, 08:09 AM   #13 (permalink)
dirtoyboy's Avatar
Bearing drag was in spec? Are you using a pull scale?
Did you measure the seal drag first?
Sounds like they are a bit tight ...yes...
I have seen quite a few trail gear bearings that have had to be ground down to fit....that really dont surprise me....
__________________
Old 07-27-2008, 08:21 AM   #14 (permalink)
no i didnt measure the drag at all, don't have a fish-scale. But it did feel noticeably tighter than the other side. Do you think this is something i should worry about, or will it loosen up on its own? It only has about 30 miles on the axle, and ill only be going 2-5 miles at a time until next weekend when ill go about 40 miles to get my rear spring hangers welded and my rear finished.
__________________
My 4runner n stuff
Old 07-27-2008, 08:38 AM   #15 (permalink)
dirtoyboy's Avatar
Ahhh you did it the old fashioned way! by feel!
If they are getting hot that is a problem. I would just take the hub off and loosen them just a bit. Shouldnt take more than 20 minutes or so....
__________________
Old 07-27-2008, 08:45 AM   #16 (permalink)
ya, i guess better safe than sorry. I just hate that damn snap-ring on the axle-stub
__________________
My 4runner n stuff
Old 07-31-2008, 08:24 PM   #17 (permalink)
...so the bearings loosened up on their own before i could replace them. And now i have a horrible squeel from all the grinding i did doing over the knuckles/brakes.
and the rear goes on sunday. Will have pictures.
__________________
My 4runner n stuff
Old 08-03-2008, 05:36 AM   #18 (permalink)
dirtoyboy's Avatar
Are you using the star washer and bending the tabs down (one forward and one backward) over the hub nuts?
__________________
Old 08-04-2008, 05:43 PM   #19 (permalink)
yes i am.
__________________
My 4runner n stuff
Old 08-04-2008, 05:43 PM   #20 (permalink)
..and a few more pics of what i did this weekend::
Those are 4" TG springs in the rear, w/ 3" TG springs in the front. The front is still sitting a little bit higher than the rear, heh. Maybe it will settle, we will see.
__________________
My 4runner n stuff
Old 08-04-2008, 06:35 PM   #21 (permalink)
coolthew's Avatar
Send a message via AIM to coolthew
Wow, it's that much higher with a V6? thats a little bit wierd...
__________________
_Matt_
coolthew is offline
Old 08-05-2008, 05:08 AM   #22 (permalink)
thats also parked on a hill..its not too bad at all, im just surprised it isnt the other way around..
__________________
My 4runner n stuff
Old 08-09-2008, 04:56 PM   #23 (permalink)
looks like im going to have to eventually fix shackle angle and myabe go with longer shackles. The front sits too high =/ Im picking up my 35" goodyear MTR tomrrow
__________________
My 4runner n stuff
Old 08-09-2008, 05:40 PM   #24 (permalink)
fillsrunner4's Avatar
Send a message via AIM to fillsrunner4
get some tires on there got to be scary as hell to drive.
Looks pretty good.
Gonna be tall!
__________________
94' toyota 4runner (Many a change!) purchased bone stock, NOW... SAS, 39" Iroks, Rear Leafswap, 5.29's , Air locked front, Welded rear, Chevy 4.3L V6, 5spd swap, dual T/C's MC10R10, flatbelly with custom skids, sliders, Chopped, Bobbed and so much more.
Might as well start reading this if ya want know more
Fillsrunner4 3.4crawler Build Thread
Fillsrunner4.3 crawler (Part Two) build thread
fillsrunner4 is offline
Old 08-10-2008, 10:51 AM   #25 (permalink)
ya, much taller than I actually wanted. Im sorta disapointed in the 3" springs up front. Might eventually do RUF.
Drove down to Austin today and bought some 35" MTRs already mounted on toyota wheels. I'll put them on later today.
__________________
My 4runner n stuff
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
So it begins...94 IFS 3.0 auto to a 3.4 SAS auto runslikecrap 3.4 Swaps 17 02-06-2008 09:14 AM
Batman Begins Churnd Off Topic Talk 6 05-04-2005 09:52 PM
And it Begins... cubuff4runner The Fab Shop 13 02-22-2005 04:41 PM
It Begins............... tkrispin Off Road Trip Planning, Expeditions, Trips, & Events 7 08-12-2002 10:16 AM
2009 InternetBrands, Inc.
