| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
preparing for a s.a.s
__________________
1991 extended cab 3.0 v6 5" trail-gear sas swap 63" chevies in rear 35x12.5 goodyear mtr's 4:88 gears with trutrac front, locked in rear warn m8000 w/arb front bumper marlin crawler rear bumper flowmaster 40 series Last edited by weakyota91; 06-28-2007 at 11:57 PM. |
#2 (permalink) |
the bumper will be useable, but you have to modify it. I'll be modifying my Warn bumper for the same.
limited slips are crappy. An automatic locker is fine. I ran a lockrite in my IFS without any issues, it deactivates in turns, so yes, you can steer. Whoever told you you can't is BSing you. I bought the T-G kit from Wabfab and it's complete.
__________________
'03 350z Turbocharged (totalled :( ) '04 Honda Accord LX V6 (first bone stock car I've owned in a while) 94 4runner SR5 4x4, 31x10.5's, SAS, Warn M8000 winch, Allpro bumper, Summit (K&N FIPK in different wrapping) CAI, flowmaster muff, 5.29's FOR SALE! '07 Harley-Davidson XL1200c, rush slip-ons |
#3 (permalink) |
Bump...I will be SAs soon
#4 (permalink) |
everyone and their sister has used that kit. It is good.
The pros of doing this with your set up is that you will look cool and have stronger steering, and more flex. The cons are that you will be as strong or at best marginally stronger than your IFS, and be only slightly more capable. Basically the cons are that you are spending a lot to gain a little.
__________________
1987 Mutant 4runner|Slightly Modified|Lacking general build direction -Lifts and Tires look cool at the Mall, Lockers and Gears look cool on the trail. -Internet Nice Guy |
#5 (permalink) |
you have got to be kidding me. I have far more flex, better approach angle, and stronger axles/steering with the T-G kit than I ever had IFS.
__________________
#6 (permalink) | |
Quote:
A Lockright that disengaged in turns? Sweet! Pros: -Looks cool on the net Cons: -Opens a can of worms
__________________
Ease on down the road. |
#7 (permalink) |
Location: Vacaville/Sierra Nevada Mountains, CA/ UNLV (Las Vegas), NV
I'll buy that ARB if your gunna get rid of it, you're just a short drive up I-5 and I'll pick it up too.
__________________
'89 Beater Jeep Eater in progress 4.88's, TRD e-locker, Dual Cases, 33's, Armored, Tread Lightly Mixchallenge.info Last edited by 89silverpu; 08-17-2007 at 10:24 AM. |
#8 (permalink) | |
Quote:
As for axles, best tests i've seen show stock birfields as, at best, marginally stronger than CV axles. Some say equal strength, but i think they are being a little too optimistic about CV's. As for capability, i was referring specifically to the system the OP specified. He will be slightly more capable with is flexy SA set up than he was with his IFS, but he will still have LSD's front and rear. He asked for opinions. More than likely he will never have an issue with his stock axles.
__________________
#9 (permalink) |
I expect to see much better results than when IFS. There were more times than not when attempting a ditch crossing (deep, narrow ditches here in FL) where IFS hindered me more than I could stand.
Oh well.
__________________
#10 (permalink) |
You will see better results.
You have more flex, and loads more ground clearance than before your swap. Just pointing out the cons to the swap he mentioned. All of those issues will be corrected if he gets longfields, and lockers. Then he will begein to see a vast impovement in capabliity, and the cromo will keep things together.
__________________
#11 (permalink) | |
Quote:
There are kits available to make this an easy job: drill and weld. In extreme cases, it can require radiator support modification. Not a big deal, but a little extra work. Here is one, the IFS HD mount kit http://www.marlincrawler.com/htm/steering.htm
__________________
1987 Mutant 4runner|Slightly Modified|Lacking general build direction -Lifts and Tires look cool at the Mall, Lockers and Gears look cool on the trail. -Internet Nice Guy Last edited by AxleIke; 08-17-2007 at 10:49 AM. |
#12 (permalink) |
oh, I'll be doing a locker up front here eventually......and I'm considering just spooling the rear......for cost/advantage sake.
__________________
#13 (permalink) |
I'd prefer to put an Aussie Locker. They're cheap and very nice. I've one in the front of my IFS and definetively will put one in the front when I SAS my rig!
David
__________________
'94 Toyota 4Runner 3.0 Turbo Diesel Intercooler Auto – Trail-Gear 4'' SAS front, Trail-Gear 5'' rear leaves swap, 35's, FR&RR E-Lockers and too many things more to write... |
#14 (permalink) |
How does putting a spring hanger on the front of the truck increase approach angle? It's the bigger tires.
I have seen trucks denied obstacles because of Detroits and similar. Spools cost more in other ways. Not so cheap when you go through tires twice as fast. Several people who never broke IFS parts ate up Stockfields on their first trips. IFS never held me back crossing ditches. Tire size, gearing and lockers did.
__________________
#15 (permalink) | ||||||
Quote:
Quote:
Quote:
Quote:
Quote:
You just need to upgrade the steering to some sort of hydro assist if you want to turn a fully locked rig on certain terrain. 9 times out of 10 you'll probably want to have a locker engaged even if it makes steering tougher. A front locker adds a ton of capability to your vehicle, and generally is easier on parts as you won't have that high wheel spin to full stop when it grabs traction. Quote:
The benefits I have found offroad from my SAS is ground clearance, more wheel travel, stronger steering components and the abilty to upgrade in terms of axles for even greater strength. I have Longfields now, which aren't available for IFS... and it's nice to have the piece of mind on the trail. Additionally, you'll get an amazing amount of room underneath to get to things like your starter or oil pan. I think general overall access for most maintenance in the front end really improves. Alignment is a breeze and can be done yourself in 5 minutes or less... not that you will ever need to... the Hi-Steer and solid axle are beefy and simple. I'd suggest adding a gusset in line with the frame behind the SAS hanger. I cracked my frame there, and after that happened it was easy to see why. Something like this: ![]() Also suggest you plate the frame at the steering box once you find out if everything will clear. Those can crack as well... mine did. Best of luck with your swap. It's a lot of work but very rewarding both in mechanical accomplishment as well as trail performance.
__________________
================ 1990 4Runner | V6 3.4 | 5spd | 240 someoddthousand miles | SR5 | SAS | RLS | 35's | ARB | TJM | 217 to 1 | W8000 - four wheels | three sticks | two hands | one trail - visit the sticki chronicles
#16 (permalink) |
What I would do is build your axle. Yota or bigger(dana or military)??? Put a high pinion front cause youll eventualy want one if you plan on SAS. ARB if you can afford of Elocker. youll want a front locker. Weld, spool or arb/elocker rear cause youll need it. with a SAS you will have more flex and chance but TRUE IFS can go if you dont do what Ive already stated. More ???'s then keep them comming cause if you plan this youve got more on your mind than just SAS trust me
I can Help
__________________
94' toyota 4runner (Many a change!) purchased bone stock, NOW... SAS, 39" Iroks, Rear Leafswap, 5.29's , Air locked front, Welded rear, Chevy 4.3L V6, 5spd swap, dual T/C's MC10R10, flatbelly with custom skids, sliders, Chopped, Bobbed and so much more. Might as well start reading this if ya want know more |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| preparing block for head gasket | bigyota36 | Pre 84 Trucks | 4 | 06-09-2007 06:41 PM |
| Preparing for a road trip | co4rnr | 86-95 Trucks & 4Runners | 2 | 03-31-2007 01:03 PM |
| preparing to install a winch. | weakyota91 | 86-95 Trucks & 4Runners | 2 | 11-23-2006 05:22 PM |
| Preparing for my lift!!! WOO WOO | carose725 | 95.5-2004 Tacomas & 96-2002 4Runners | 5 | 06-28-2004 07:53 PM |
