IFS Front Driveshaft
Old 04-29-2007, 10:09 PM
captwalker87's Avatar
Besides length, is there any other reason that I cannot use the IFS drive shaft to accomdate my low pinion solid axle swap? I would prefer to keep the double cardian at the transfer case. Just to extreme of an angle? I am sure this has been covered, I just cannot seem to locate the exact answer I am looking for. Thanks.
Old 04-29-2007, 11:12 PM
Elvota's Avatar
It's not only the length of the DS but the amount of slip it has. You'll need maybe 6" to 8" of slip with a SAS. The IFS shaft has maybe 3" max. PLus you'll need an longer DS from end to end.
The stock double cardian needs to be modified to allow for more aggressive working angle as well. Most ditch the DC for a standard CV at both ends.
If you are on a budget, a long slip DS can be made with two pieces of hitch stock. Should be under $60.
Old 04-30-2007, 12:15 AM
Sponsor
Tofer's Avatar
here's mine http://www.eakland.net/joey/DSC_1481.JPG
and for the record thats mud not rust
Old 05-01-2007, 05:41 PM
Superflex84's Avatar
The IFS DC does not have as much movement as the 79-85 DC.
I am dealing with this problem right now. I think I'm going to use a 85 shaft with a 8" slip(for use on my 3" trail gear kit).
make a square shaft, or find a good 85 or older front shaft to add a slip to...
Old 05-01-2007, 07:27 PM
Phalanx's Avatar
I used my IFS drive shaft with my SAS. I had the 8" spline from Marlin installed and I had to grind down the CV joint a little.
Flying91
45
04-11-2024 04:39 PM
88sasturbotoy
08-11-2015 01:56 AM
deepmarsh
08-06-2015 03:44 AM
coffey50
07-28-2015 10:55 AM
scottyg486
07-19-2015 05:34 PM
Quick Reply: IFS Front Driveshaft
