Thread Tools | Search this Thread | Display Modes |
#1 (permalink) |
I'm removing the rest of the IFS brackets from my truck. How much should I cut the motor mount/upper control arm bracket to weld in the motor mount plate? I've seen many different pics on this. Is it user preference?
(I'll be using Marlins 5" SAS kit) Does anybody have any top down pics showing just how close to the motor mount was cut off? Thanks. |
| Sponsored Links |
#2 (permalink) |
Its more of a preference thing....just do what you think looks good...
leave enough room on the top of the mount for your gussets ![]()
__________________
Low down and durrrrrrrty Rock stacking Web Wheeler. I'm the yota junk man......PM me for ALL your parts needs NEW or USED Locked, lifted, trussed, SASsed, triangulated, dual cased, shaved, armored, gusseted, hydro'd, blacked out, crapped out, mashed up, merderrrrrd out and ready to hit the mall! It's a Jaap thing....You wouldnt understand |
#3 (permalink) |
I haven't seen the gussets welded on like that before. I was going to cut alot off, but agfter seeing that pic. I'll leave enough in case I need to mount the gussets like that.
Thanks |
#4 (permalink) |
Yea well you need to leave enough for support for the motor mount too...I would cut them pretty much flush with the outside edge of the frame
__________________
#5 (permalink) |
As dirtytoyboy sais I cut mine flush with the frame so when you cap them with the plates supplied you get a nice flat surface with the frame rail.
David
__________________
'94 Toyota 4Runner 3.0 Turbo Diesel Intercooler – Trail-Gear 4'' SAS front, Trail-Gear 5'' rear leaves swap, 35x12.5x15 M/T's and too many things more to write... |
#6 (permalink) |
__________________
1988 4runner w/ 5'' SAS Trail Gear Kit, 3'' body lift 5.29 with Detroit Lockers, and 35'' Iroks 2002 Chevy Z71 w/ 6'' ProComp stage two suspension, 3''body lift and 37'' SSR http://bslca.com/ |
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| How do you know a motor mount is broken? | tc | 86-95 Trucks & 4Runners | 51 | 06-28-2008 09:39 PM |
| Motor Mount Issues | strykersd | 86-95 Trucks & 4Runners | 5 | 04-11-2008 12:43 PM |
| motor mount? | elnido | 86-95 Trucks & 4Runners | 2 | 11-11-2006 04:14 PM |
| motor mount help | 81yota | Pre 84 Trucks | 1 | 05-04-2006 03:33 PM |
| Need to cut a section out of my cab mount . | yoda92 | The Fab Shop | 4 | 10-28-2005 07:41 PM |
