Good SAS Kit
Well, currently aren't many out for your model truck.
You could probably adapt the ORS kit for a taco to fit, but hard to say.
http://www.offroadsolutions.com/prod...ilover_systems
Essentially, you are looking at building it yourself. You can maybe adapt a kit from Trail Gear, but its hard to say, since your frame is different. Anyway you do it, hopefully you are a pretty outstanding fabricator.
Good luck
Good luck
Get a diamond axle and 3 link it! I don't think there is anyone making complete kits for leaf sprung set ups like you can get with pre 96 models. Poke around on TTORA.. gobs of SASed Tacos over there.
Allpro offroad makes a decent 3link kit for the front of Tacos which should be very similar to your 4runner also ORS makes a longer travel one aswell i would go with. The rear eaither go with some new taller coils and keep your linked rear or swap in some leafs. If your going to get into a SAS building your own parts can save you alot of money. Be creative and i dont really think there is ONE great kit out there because they are all so similar really. You could use alot of parts from SAS kits for say the older trucks and make it work for you. Do some research on SAS 4runners I know there is alot of info out there for you.
I think buying parts (steering, shocks, hangers, springs or coils, ect) and building your own kit may be the way to go
XtraCab
04-12-2020 05:25 AM
jerusry
10-19-2015 05:28 PM
09-04-2015 09:27 AM
crashburnoveride
07-10-2015 06:39 AM
