YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Off Road Tech, Fab Shop, Solid Axle Swaps, Tool Time, & Engine Swaps > Solid Axle Swaps, All Years
Home Photo Gallery Register Search Today's Posts Mark Forums Read Tread Lightly Wiki
Thread Tools Search this Thread Display Modes
Old 04-17-2008, 09:47 AM   #1 (permalink)
cootees's Avatar
Send a message via AIM to cootees
90 2dr sas
So this is the big weekend for the 4runner.
So here is what we are working with. 90 4runner 2dr. Trail-Gear 3" ifs eliminator with the creeper gussets.
Here she is in the current state.
Here is the axle when I picked it up.
I just finished welding and cleaning up the axle housing and having it powdercoated so here it is in its current state waiting to be reassembled.
I still need to take a wire wheel to the knuckle balls to clean up the overspray. But reassembly will take part tomorrow and saturday we will start the cutting.
__________________
-- '90 4Runner 2Dr
3.0 / sas /FJ80 rear coils / rear e-locker / 32's/ MC Rear bumper / TG Sliders / surco basket / cobra 18 wxstII / ISR / Magnaflow exhaust
cootees is offline
Sponsored Links
To remove this ad, register today!
Old 04-17-2008, 10:39 AM   #2 (permalink)
Staff
UKMyers's Avatar
Send a message via AIM to UKMyers
Be sure and take lots of pictures!! Make sure you buy 5 or 6 grinding wheels for after the IFS comes off!
__________________
2006 Tacoma TRD offroad 4.0 Access Cab 6 sp 3" Revtek, 285 BFG's, Borla Catback, Volant Intake, Billet Grill, Split Second PSC1 Professionally dyno tuned, URD Short Shifter Kit, 226 RWHP
1994 4-Runner SR5 5 Speed SASed, Detroits, Armored, Dual Cases, 37" MTR's See my build up thread here http://www.yotatech.com/showthread.php?t=104000
Quote:
where on the 3vze manual is the transmission dipstick?
Quote:
what is sas?
UKMyers is offline
Old 04-17-2008, 03:04 PM   #3 (permalink)
What are you doing in the rear?
Jeremy
Wheelingnoob is offline
Old 04-17-2008, 03:47 PM   #4 (permalink)
cootees's Avatar
Hopefully I am keeping the rear the same. I have not read anywhere what the difference will be. I'll have to see if it will be much of a difference.
If that doesn't work I'll have to find some different springs or temporarily go with spacers. I'm keeping coils in the rear though. No doubt about it.
__________________
-- '90 4Runner 2Dr
cootees is offline
Old 04-17-2008, 10:33 PM   #5 (permalink)
Good luck man, I just finished my SAS on my 93 2rd Runner and its way high. I got about 6.5" of lift in the front with the 3" TG swap kit. You will need to find some big ass springs, I put in OME 862's and it was still 4" lower in the back. I added 2" spacers tonight and it looks a bit better but still lots of sag look in the back.
I hate to say it but I think I'm going to end up with leafs in the back. Now that I have the truck almost level when ever I turn left the drive shaft hits the gas tank. I cant even drive the truck right now as it is, and I have a 4" panhard drop braket on there.
I'm lookign at getting some 07 taco rear leafs or Chevies.
Godd luck with the swap, its not tha hard part the hard part it getting it to all work right after.
Jeremy
Old 04-22-2008, 08:36 AM   #6 (permalink)
backwoods_bently's Avatar
what all does it intell doin the sas? im readin up on i, but i still aint real sure about what all it really intells. any help? is it alot of cuttin and weldin?
backwoods_bently is offline
Old 04-22-2008, 09:52 AM   #7 (permalink)
dirtoyboy's Avatar
Quote:
Take a look here>>
http://www.marlincrawler.com/suspension/sas_inst.htm
I usually recommend moving the steering box to correct the whack steering geometry after its lifted
__________________
Low down and durrrrrrrty Rock stacking Web Wheeler.
I'm the yota junk man......PM me for ALL your parts needs NEW or USED
Locked, lifted, trussed, SASsed, triangulated, dual cased, shaved, armored, gusseted, hydro'd, blacked out, crapped out, mashed up, merderrrrrd out and ready to hit the mall!
It's a Jaap thing....You wouldnt understand
Quote:
Originally Posted by SwampThing View Post
Oh, after a consult with Mr. Anheuser, I think I beer-stormed a way to test the gears
dirtoyboy is offline
Old 04-22-2008, 09:55 AM   #8 (permalink)
AxleIke's Avatar
Leaving the rear coiled can result in screwy handling, and will probably mean that only one end will do the work, likely the rear, when flexing. We'll see when you get it done, but I'm betting a leaf spring conversion is in the future.
__________________
IFS SAS
My mods aren't bling enough for the signature line.
-All Terrains are for when you know how to drive.
AxleIke is offline
Old 04-22-2008, 10:07 AM   #9 (permalink)
run4her's Avatar
I am keeping couls in the rear. We are just added 20" to the main links and moved the brackets foreward. Next i am putting my gas tank in the bed and going to move the 2 center links.
__________________
1990 4runner. 42/14/r.17 irocks, spool in front. Sas, lc coils and triangulated 4-link. 1in bodylift, 7in front screen linked to 14in flip down in rear, Chopped, Bobbed 33". Wheelbase stretched 7".
1984 extra cab pickup. 7" suspension lift, 36" Radial tsl's, Bobbed 12"
run4her is offline
Old 04-22-2008, 05:13 PM   #10 (permalink)
LTrunner's Avatar
i bet the 3' SAS kit will be really high in the front they all are at first but with a later modletruck and a v6 they will settle down alot....i've seen som go from about 5-6" down to 3-4" anyways good luck
__________________
89 4runner 3.0L, 5spd swaped
like what ya see...check my build
http://www.yotatech.com/f116/my-very...runner-143762/
Don't Follow me, you won't make it
"Wheeling the piss out of it" AND "DD"ing it since 2005
LTrunner is offline
Old 04-23-2008, 10:48 AM   #11 (permalink)
My truck after a week of sriving with the 3"SAS kit is still way high in the front. I have OME LC coils in the back and 2" spacers and there way to soft the truck is scary to drive. if I was to do the coil rear again I would get the 3.5" 80 series heavy lift springs and try and get some of the stabillity back. Right now the rear liks are maxed out and I awesome rear steer around corners. My rear axle is also pointing 3/4" to the pass side.
I'm seriously looking at losing the coil rear end in favor of leafs. Not that I really want to, I love the way the coils ride on the street and off road but for safty I think its needed.
Old 04-23-2008, 01:30 PM   #12 (permalink)
Blizzard's Avatar
Send a message via MSN to Blizzard
Quote:
True, this is why I choose to do leafs all around...
David
__________________
'94 Toyota 4Runner 3.0 Turbo Diesel Intercooler – Trail-Gear 4'' SAS front, Trail-Gear 5'' rear leaves swap, 35x12.5x15 M/T's and too many things more to write...
Blizzard is offline
Old 04-25-2008, 01:04 PM   #13 (permalink)
cootees's Avatar
We will see how it handles with coils in the rear. It is not my daily driver so I should be able to bear it.
Whats the trick to getting the knuckle bearing races seated? I even froze them overnight and that did not help any.
__________________
-- '90 4Runner 2Dr
cootees is offline
Old 04-25-2008, 01:52 PM   #14 (permalink)
Belize Off Road Team's Avatar
Send a message via MSN to Belize Off Road Team
when i get around to doing my sas, it'll be coils all around. better performance, much better ride and it just looks unique on a Toyota.
__________________
-Phyl
1991 Hilux Surf SSR-G Petrol 3.0L V6 193,000kms l 3.4L V6 264,000kms to be rebuilt then installed! l Rancho RS5000 l 31"x10.50"xR15 Pro Comp Xterrain l K&N Drop in filter l PP 1" Lift Coil Springs l TRD shift knob l Lv. 3 First Aid Kit l White Gauges & Temp Controls l LED conversion l 80/100W Hella H4 l Hella Black Magic l 1st Gen Roll Bar Mod l FT/RR Diff. Breathers l Smittybilt XRC8 Winch l
TOYOTA TOUR 2008
トヨタ|NEVER QUIT
Belize Off Road Team is offline
Old 04-25-2008, 03:10 PM   #15 (permalink)
Sponsoring Member
waskillywabbit's Avatar
Send a message via AIM to waskillywabbit Send a message via MSN to waskillywabbit Send a message via Yahoo to waskillywabbit
Brass drift and a hammer...gradually tap them down.
waskillywabbit is offline
Old 04-28-2008, 03:50 PM   #16 (permalink)
Quote:
X2 Worked great for me!
Old 05-22-2008, 06:43 AM   #17 (permalink)
cootees's Avatar
So here is an update. As you can see I am takin gmy time with it working on it when I get the chance.
The point of no return.
bye bye half shaft
I am now realizing how much of a difference it is going to be in the front. So i'm trying to plan on what to do to lift the rear. I really don't want to give up the coils but at the same time I don't want it to be so tipsy. Any solutions?
__________________
-- '90 4Runner 2Dr
cootees is offline
Old 05-22-2008, 09:20 AM   #18 (permalink)
I ended up doing a leaf swap on the back of mine and am very happy I did. If you want to keep coils you will need to remake all the rear links and fit big coils. The problem is when you lift it to the point that its not sagging in the back the links are just to short. You are better off making a full custom linked rear end like the trail gear 3 link set up. Problem with that is the cost and then you still need coilovers or air shocks.
Leafs is the cheapest and most common thing (becuse it works). I used chevy 3/4 ton 63" leafs in the rear of mine and the ride is good and I have a the rear the same hight as the front now. Once you have done the SAS on the front the leafs swap on the rear is a breeze.
Good luck and keep us updated.
Jeremy
Old 05-22-2008, 10:19 AM   #19 (permalink)
cootees's Avatar
Yeah. Regardless what I do to the rear if I am lifting it more with keeping coils then I will have to extend the control arms and have a new panhard bar made up.
Wheelingnoob, you did a 3" tg kit right? What coils did you have to begin with? I'm wondering how much more lift I will need in the rear over the fj80 coils that I currently have back there.
__________________
-- '90 4Runner 2Dr
cootees is offline
Old 05-22-2008, 10:54 AM   #20 (permalink)
Yes I do have the 3" sas kit, the coils I was using were the OME 862's there a 80 Series rear coil that gives them a 1" loft and is rated for 250lbs more payload. I had then add a 2" coil spacer to them and I was still low in the back and had maxed out all my links at that point.
If you have the stock 80 coils in there now I would say easally 4" more lift. The 3" sas kit gave me about 6" of lift over stock. and about 4" over my BJ spacers.
Part of my problem is the 2" BL that I need to take out ASAP! That will help the look of the truck greatly.
Jeremy
