88_Red_Runner's Tired Of IFS...
Old 12-21-2013, 05:29 PM
88_Red_Runner's Avatar
Will post more pictures tomorrow. Stay tuned.
Old 12-21-2013, 05:34 PM
Side shot with black top. Old suspension 4" pro-comp drop lift and 4" blocks in the back. Previous owner did this to it. Blown up 3. slow and automatic.
Old 12-21-2013, 05:35 PM
I'll post more tomorrow. Tell me what you guys think.
Old 12-21-2013, 05:58 PM
BigBluePile's Avatar
Um....good start......?
Old 12-22-2013, 03:58 AM
So herre are the plans for it:
58" All Pro Offroad 4" Tacoma rear springs.
2002 Tacoma E-Locker rear axle.
Hybrid rear up front pack.
14" 5150's all the way around.
Extended brake lines.
T100 master cylinder and brake calipers.
Yukon 5.29 gears.
FJ80 Hi-pinion front differential.
Longfields and cromo hub gears.
U-Bolt flip kits.
Please excuse the mock up axle and rusty springs. That is all cleaned up now. I also decided to french the front hanger in to lower it. More pictures later tonight of that.
Old 12-22-2013, 04:41 AM
Here is a photo of the rear. 58" all-pro 4" Tacoma springs. Putting in the e-locker today. 90-95 rear coil spring bump stops work well. They squish a lot.
Old 12-22-2013, 05:00 PM
Front hanger all welded up notched in one in a half inches.
Old 12-22-2013, 05:03 PM
Shackle angle.
Old 12-22-2013, 05:07 PM
How the front end is sitting now. Still need to make shock hoops and bump stops.
Old 12-22-2013, 05:09 PM
Out with the old.
Old 12-22-2013, 05:12 PM
In with the new.
Old 12-22-2013, 05:16 PM
How the rear sits. Still need to move the shackle hangers back to level her out.
Old 12-22-2013, 05:19 PM
Little preview of what else I have in mind.
Old 12-22-2013, 05:24 PM
Here is a shot of the pinion angle for the front. Sorry for the blurry photo.
Old 12-22-2013, 05:28 PM
Tomorrow I will post some more pictures. I will be using a temporary front drive shaft that fits. Its an 01 3rz manual transmission front drive shaft. No CV's front or rear on this 4Runners build. I'll be using a limiting strap on the passenger side so the slip yolk will not separate.
Last edited by 88_Red_Runner; 12-22-2013 at 05:35 PM. Reason: forgot to add something
Old 12-22-2013, 05:39 PM
Hope everyone enjoys and any questions feel free to ask. Happy holidays!
Old 12-22-2013, 08:02 PM
Clever idea on the front hangar
Old 12-23-2013, 02:22 AM
Thanks. I wanted the front to sit fairly low. I did not want to get too crazy with the steering box. So I only notched the hanger in 1.5 inches.
Old 12-23-2013, 07:31 AM
JonnyBoy's Avatar
I know you already said hybrid rear pack, but what's your spring pack? I'm assuming it's at least the top couple leafs from your '88 rear pack, so what else? Could I maybe see some pics of your steering box setup, too? Just trying to stay kinda low on mine when I do it, too, so it'd be nice to see how you've done it and if you run into clearance issues. Thanks man, and the ride height looks good so far.
Old 12-23-2013, 10:22 AM
Erik Hinch's Avatar
Looks Great.
What did you do with the old bracket lift?
My son might be interested in it.
Quick Reply: 88_Red_Runner's Tired Of IFS...
