The 28th Annual Hump N Bump will take place
November 7th and 8th 2008.
28th Annual Hump n Bump CLICK FOR INFO
this year we have reserved the County Fair grounds for camping
it has power / water and lots of room for all the RV`s
The Trails!
The follow trails will be ran this year:
Arockalpse - Extreme trail with a gigantic boulder at the beginning. This trail is rated 4 and should not be attempted unless you have 35"+ tires, 2 lockers and do not care what you vehicle looks like!
Bowl Trail - Perfect trail for those with stock to lightly modified vehicles. The trail winds through the desert through some very scenic parts of the Logandale area. There are a few obsitcles for those of you adventurous types but all are optional. At the very end of the run you can really test your driving skills and attempt the S-TURN. Though it is optional we suggest lockers front and rear and there is a possibility for some body damage. Full size not recommended in the S-Turn and are guaranteed body damage.
Bronco Falls - A trail named after the one biggest obsticles in the trail, a huge vertical climb up a rock wall. Though it looks more intimidating then it is difficult a good set of tires and some low gears will get you to the top.
Hawkins Trail - Scenic trail that takes you through the mountains to the valley adjacent to the Logandale Valley. This is the connector trail for many other trails such as Matterhorn, Arockalypse and The Bowl trail. So if your looking for a scenic easier trail take the Hawkins Trail.
Matterhorn - Rated probubly a 2 this trail is good for those slightly modified vehicles. Scenic ride through the Logandale hills to some mild obsticles. Great optional off camber climb just before a large climb that puts you back in the launch postition.
Rock Bottom - This is a great trail for those looking for a challenge. Rated a 3+ this trail will test your rig. The entrance to the trail is a V notch that you tip toe through. From there you crawl some sand stone obsticles along the way until you end up in a canyon with 4 ways out. The easiest is rated a 2 or 3 the hardest put mosts on there roof! As the trail comes to an end you have two ways to exit the trail: the S turn near the end of the trail where your powersteering, gearing and brake control abilities get a major workout or the waterfall which is pretty steep flat rock wall decent. After the trail have some fun at the sand dunes and back to base camp. Trail will take about half the day with a large group so bring snacks and plenty of water.
****ter Trail - This trail will challenge the stock the vehicle but still have excitement for those modified rigs with some optional obsticles. This trail is also close to base camp and is famous for unofficial night runs. Rated about a 2-3 depending on the optional obsticles.
Nevada BackRoaders are leading some scenic trails
Bitter Springs and The Logandale Loop.
Please note:
The Country Fair Grounds have 110 power / water / restrooms
to use this facility we need to add a RV fee.
$20.00 for the event
New Information:
No Fee for tent camping on the grass
No Parking on the grass
There is an area wide enough next to the grass and RV`s
that will be reserved for tent camping
We have new vendors for this year that want to come set up a display of their products.
We had over 15k in prizes to give away last year. We expect a lot more this year.
** ARE YOU READY TO REGISTER? **
Register Online
*MS Internet must be used fill out the form*
There was even a FJ Cruiser at last years Hump N Bump & press coverage
http://www.4wdandsportutility.com/ad...ide/index.html
Hump N Bump media coverage from years past
2004/24th Four Wheeler
http://www.fourwheeler.com/eventcove...ump/index.html
2005/25th? Off-Road Magazine Land Rover Disco feature @ Hump N Bump
http://www.off-roadweb.com/features/...ver/index.html
2006/26th JP Magazine
http://www.jpmagazine.com/eventcover...ing/index.html
Pics My MudPro @ written by Mo
2006/26th J Rations
http://rides.webshots.com/album/556474363PGHNMJ http://store.jrations.com/product_in...2b041c142d68fb
2007/27th 4WD & Sport Utility
