93-98 T100s All T100 trucks
Voltage Running High, Killing Alternators
Old 03-26-2016, 06:42 PM
Winkel's Avatar
Hey Guys,
I have a 1998 T-100, 4wd automatic, extended cab. It has 254,000 miles on it and has always been extremely dependable. I've done all the required maintenance for the past 14 years and then some.
For the past couple of years, the voltage has been running high, the alternator runs hot and I smoke an alternator every couple of years. My battery terminals are clean and the frame doesn't have a lot of rust on it considering it's age.
I verified the voltage with a multi meter and it shows high on my compass/voltage Road Pro unit. Tonight it was running 16 to 18 volts.
I assume I have a ground connection somewhere that is rusty or something.
Any ideas???
Thanks,
Winkel
Old 12-10-2017, 12:10 PM
Tilikum102602's Avatar
install more grounds.
Old 12-10-2017, 03:15 PM
akwheeler's Avatar
It's more likely to be a poor connection on the sense wire that controls alternator charging, it sees low voltage so cranks up the output of the alternator. I don't have any diagrams or experience with that vintage so I can't be much help in troubleshooting it.
Old 12-10-2017, 06:05 PM
RAD4Runner's Avatar
LOL!
Originally Posted by akwheeler
It's more likely to be a poor connection on the sense wire .
This^^^
Just find schematic, find "S" wire, make sure it is making good connection from battery / fuse block to "S" pin of alternator connector.
Old 12-11-2017, 06:24 AM
skypilot's Avatar
Maybe and upgrade to a GM one wire setup is in order. More output for stuff.
Old 12-11-2017, 07:46 AM
akwheeler's Avatar
I did a GM one wire conversion on my old 1980, unfortunately it was overcharging so I built my own regulator with some ballast resistors and a relay. I just put different resistors in parallel until I got the voltage I was looking for during normal driving (about 14 volts) and when I turned on the headlights it energized the relay which bypassed the ballast resistors. I was pretty proud of that setup, but it's much better to get the stock setup working right, or at least keep it from looking like a hack job. I did it on a hunting buggy that really didn't matter as long as I knew how to troubleshoot it.
Old 12-11-2017, 08:10 AM
RAD4Runner's Avatar
Nice for the electrically-savvy, but for those who are not that would be jumping from one fire to the other.
Daniel Castaneda
03-29-2016 11:22 AM
richdavies
12
03-14-2016 05:05 PM
usmma2013
03-06-2016 07:52 AM
TmbrWlf
03-01-2016 09:34 AM
Quick Reply: Voltage Running High, Killing Alternators
