93-98 T100s All T100 trucks
Steering Rod Recall
Old 12-09-2009, 12:48 PM
snowfighter's Avatar
Steering Rod Recall
Everyone probally knows about this but being I bought my 1993 T100 last July I found on recall list about the steering rod recall, called dealer and my vin hadn't been done so taking in next week,service dept said they change steering rod,check and change tie rod ends if needed, and aline front end all under warranty no charge.
Old 12-09-2009, 02:47 PM
DJ99's Avatar
Yes, your previous owner may be the last to know.
When I had the head gasket recall done years ago, the local Toyota dealer gave me a free rental car for a day. Doubt you'd get that now. No such luck on the steering rod recall.
They couldn't break mine free without some intermediate part breaking, so I got that for free too. Now I'm living in salt-free land, so all is good.
Old 12-09-2009, 03:31 PM
Water pump going to couple drips now and then so having them do that and timing belt /water pump at the same time. I asked if they change the idler when they do the timing belt, response was they check it but very seldom see them go bad??? Found out when they checked the recall that the head gasket recall was done in 1998.Does the head gas fix do it for ever and ever or is it a problem spot?
Old 12-09-2009, 03:40 PM
DJ99's Avatar
I wouldn't worry about the HG fix. I would DEFINITELY have the water pump and tensioner replaced while it's all apart, especially if you're over 90K or so in mileage. Disregard what the dealer says, because they want to see you soon.
Old 12-09-2009, 03:47 PM
They told me they would install it if I wanted to buy it no charge being they have it apart.
Old 12-09-2009, 03:53 PM
DJ99's Avatar
Good, if "no charge" means "dealer cost", or less.
Old 12-09-2009, 03:54 PM
I see when I looked up the parts theres a tensioner and idler pully would one want to do both?
Old 12-09-2009, 04:01 PM
DJ99's Avatar
Do both!
Buy this for $87 bucks shipped and tell them to install it! It may cost you a bit more, but it's worth it.
http://cgi.ebay.com/ebaymotors/93-95...Q5fAccessories
What's your mileage???
Old 12-09-2009, 04:23 PM
123000 miles
choppe777
05-16-2016 08:00 AM
128keaton
09-03-2015 05:09 PM
moparbay
09-03-2015 12:48 PM
dlaiben
3.4 Swaps
09-03-2015 09:57 AM
dguzzi
09-03-2015 08:48 AM
Quick Reply: Steering Rod Recall
