Jammed Lock - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 93-98 T100s
Welcome to Yotatech!
Welcome to Yotatech,
Old 01-19-2009, 10:23 PM   #1 (permalink)
Jammed Lock
I have manual Locking doors on my truck. My problem is I can't unlock the driver side door using the key. N E 1 have an idea to whats wrong and how to fix?
Sloth21 is offline
Old 01-20-2009, 06:58 AM   #2 (permalink)
Staff
aviator's Avatar
I had a similar problem with the pax side door on my 94 once... basically the lubrication had worn off and the linkage had seized up. I pulled the inner door panel, removed some old pine tree needles that were biding around the mechanism {no idea how they got there}, fiddled with it a bit manually to free it up and white lithium spray greased the thing like crazy. since then no issues [touch wood]....
hope this helped
edit: you may also have a problem with the key cylinder it self sometimes they get corroded and the pins seize. if they do not move freely they will not engage the key properly and the cylinder will not turn.
i'd try a lock de-icer spray with a hot key followed by a a good shot of graphite lock lube and see if that frees it up before you pull the door panel.
If you need a new cylinder almost any locksmith shop will be able to recode the replacement to match your existing key for around $20
__________________
Silver 1994 Hilux Xtra cab 4x4 3.0
K&N cone filter, ported MAF, advanced timing, oversize exhaust, free flow cat, "rumble" muffler
custom covered SR5 seats, map lights, factory AC
tv4184 style black interior conversion started
mods to come... header,
custom centre console, stereo upgrade
tinted windows
Founding member 1972TLC fan club - Get well soon Mary
Toyota Hilux... Get in or Get out of the way.
aviator is offline
Old 01-22-2009, 03:39 PM   #3 (permalink)
Thanx I will try that
Sloth21 is offline
Old 01-24-2009, 12:49 AM   #4 (permalink)
Has it always been this way when you bought the truck? New or used? If used and it's always been this way...are you sure the key going to the door matches the rest of the truck?
BamZipPow is offline
Old 01-25-2009, 10:35 PM   #5 (permalink)
No this started happening last september.
Sloth21 is offline
Old 02-18-2009, 06:08 PM   #6 (permalink)
I tried the lock de-icer then put sum lube in there and its still jammed
Sloth21 is offline
Old 02-18-2009, 08:36 PM   #7 (permalink)
Here's some insight on how to disassemble/reassemble the lock if yer willing to give it a try... []
You might be able to source some locks at the yard, too...
Old 02-19-2009, 04:10 AM   #8 (permalink)
GSGALLANT's Avatar
A quick shot of PB Blaster in the key cylinder is what I used to free up two seized lock cylinders this past weekend. It worked in approx 5 seconds, and they are now just like new. If it's the linkage that's seized, you'll need to take the door panel off.
__________________
2002 4Runner, Auto-A340F, 3.4L, 4.30 Gears
TJM T15 Front Bumper & Warn M8000, 4xInnovation sliders, Sonoran Steel 1.2 Lift, Toytec LCA Skids, Tundra Brake Upgrade (231mm), Extended rear diff breather, Deckplate Mod, Andymod, Dual batt setup with Optima blue top aux battery, Hardwired 1000W inverter, Aux fuse box, Full time power to 12V plugs, Yaesu FT7800R Radio, "4-air" system for airing up/down tires.
2004 Camry LE - stock (and will stay that way)
1993 4Runner has been sold
GSGALLANT is offline
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Rear Electric Window Keyhole Jammed Johannes 84-85 Trucks & 4Runners 3 11-07-2008 07:20 PM
Need help, Jammed Dizzy zachb55 86-95 Trucks & 4Runners 8 01-04-2008 10:20 PM
jammed cd player burke neville 99+ Tundra, 00+ Sequoia, 98+ Land Cruiser/LX470 2 08-22-2006 02:29 PM
5speed tranny jammed in reverse?!?! 4RocRunner92 General Vehicle Related Topics (Non Year Related) 12 05-12-2006 08:20 PM
Good Antenna? and a jammed CD player Scarbro22 95.5-2004 Tacomas & 96-2002 4Runners 3 09-02-2004 08:12 AM
2009 InternetBrands, Inc.
