93-98 T100s All T100 trucks
Best Radiator
Old 12-12-2015, 06:44 PM
8lugnuts's Avatar
Best Radiator
My '96 T100 5VZ-FE auto needs a radiator. I read a bunch of posts here warning about the auto store chains cheap radiators and about other auto part store radiators that require hardware and/or fabrication. I've also seen some posts about high performance radiators that costs >$250 but all I need is a radiator that will last as long as my original (145K) and is a direct fit. I've searched the Internet a lot but cannot seem to find what I need. If you have replaced yours I would like to know what you used and how it went. I appreciate your input.
Old 12-13-2015, 03:39 PM
donomite49's Avatar
CSF copper/brass all metal
Had mine about three years
Old 12-13-2015, 07:36 PM
8lugnuts's Avatar
Thanks for the response Don. My T's OEM rad is a plastic cap model and believe it or not the tanks are in excellent shape, it's the core that has started leaking. I've kept the coolant in my T fresh since I've owned it so the innards are as clean as a whistle and as red as it was when it was new(Pentofrost A1). I looked up CSF radiators and the only thing that's come up so far is a plastic tank model. You wouldn't happen to have the all metal CSF radiator part # for my T100 would you?
Old 12-14-2015, 10:01 AM
Janos01's Avatar
The OE radiators that O'Reilly's sells aren't bad and they are a direct fit. Got mine for $150 for my 90 4 Runner. Eventually tho, I am going to get a performance radiator.
Old 01-28-2016, 01:26 PM
noahrexion's Avatar
DENSO 2214102 - should be in the $80-100 range
mct75
03-21-2019 01:55 PM
TURBOrunnerNM
10-05-2015 03:10 PM
89YodaRunner
09-30-2015 02:18 PM
irv
09-29-2015 06:20 PM
accuracy
09-20-2015 07:44 PM
Quick Reply: Best Radiator
