| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
5 speed drops out of 1st
#2 (permalink) |
Sorry this is so late, but I am in the process of replacing my shifter seat and socket, because of similar symptoms.
http://www.off-road.com/trucks4x4/ar....jsp?id=186539 My shifter seat looks about like the old one in the picture on that website, and I'll bet you will find yours in similar shape. A new set can be had for $16 plus shipping from www.marlincrawler.com that is supposed to be better than stock.
__________________
1993 T100 3.0L V6 3VZE 4x4 (47K) Last edited by DJ99; 09-04-2009 at 03:04 PM. |
#3 (permalink) |
Staff
You can try to shifter seat first. If that doesn't work, you have a problem in the transmission that will require rebuilding the trans. My 1990 4Runner used to do this exact same problem. The syncros in 1st wear out and allow the trans to pop out of gear on acceleration and deceleration.
__________________
Tacoma miniheader install kit Now available! Click here for ordering information Need that hard to find part? Nix99 Used Toyota and Lexus parts! |
#4 (permalink) |
Good advice DeathCougar. It's free to take the shift lever off, and it takes maybe 5 minutes. It will be obvious when you look in there!
__________________
1993 T100 3.0L V6 3VZE 4x4 (47K) |
#5 (permalink) |
awww. man... DC... that's some news I didn't want to hear (seeing as I just had the clutch replaced ...and I dont have a shop to do my own work in out here)
the shift lever seat and bushing were my first choice replacement as well, took about 1 hour tear down to cleanup... it helped in the play and most other gears as far as sloppy shifting, but Im guessing the synchros are out
__________________
Detroit lockers / LSD // 5.29 // Alcoa Classics// 33" TSL's // 4" lift // rear bags // Sway-a-Ways// Brush Guard w/5" spots // Step Bars/Plates // Borla // Centerforce// k&n Intake |
#6 (permalink) |
Ordered the seat and socket
I have ordered a seat and socket from Marlin Crawlers. If they ever show up, I will install them.
If that does not fix my problem I will decide if I want to go into the tranny to replace the spring locks and whatever else is worn out. jrohland |
#7 (permalink) |
Staff
Well in that case, its all unicorns and rainbows and ice cream
__________________
| Tags |
| 1st, 9398, gear, toyota, truck |
