Thread Tools | Search this Thread | Display Modes |
#1 (permalink) |
Wire Size for Autometer Gauges
I'm trying to hook up my autometer temp gauge and need to know what size wire to run. The instructions say it has to be protected with a 4amp fuse so I have my limit, I'm only going to be running the wire for no more then 3-5 feet so i was thinking I could use 20ga wire since thats what I have. What does everyone think is 20ga wire to small for 4 amps? My air/fuel gauge has 24 gauge wire and it says to protect it with a 5 amp fuse.
| Sponsored Links |
#2 (permalink) |
the 20 should be perfectly fine, all of my gauges on a previous vehicle (boost, fuel pressure, and oil pressure) all had 24awg from autometer.
__________________
Toyota noob. Looking for 89-94 to have some fun with. |
#3 (permalink) |
email autometer. Im sure they could help you out... Or you could just wire in a fuseable link and stuck a 4amp fuse in there...
__________________
91 Pickup - xcab - 5sp - 3.0 - sr5 - 4x4 - 230,000kms |2.25" catback w/ magnaflow cat + glasspack | Weasy2k cams | Aisin manual hubs |Diff breather mod | Marlin HD clutch |3" BL | es3000's |2" AAL |1.5" bj spacers | ISR | Alpine headunit | 4" Infinity fronts/5" rears | 4.88's |Rear lockright | 33x12.50" BFG M/T on 15x8" steelies |Hella 500's |4" reverse lights| Grant GT |Downey idler arm brace|hella E-codes| Marlin armor | %100 Amsoil synthetic http://www.cardomain.com/ride/2572486 |
#4 (permalink) |
you'll be fine with 20 for sure.
make sure you fuse it though, don't want to blow stuff out, that's never good
__________________
"alot" is not a word. it's "a lot" get it right |
#5 (permalink) |
^ Ditto. Just protect yourself from getting wires mixed up. Those gauges arent pushing any power through those wires under normal operating conditions.
__________________
#6 (permalink) |
Thanks for the help I ended up useing 20 and 18 gauge wire with inline fuses, no problems so far. If you want to see the almost finished product look here http://www.yotatech.com/f115/gauge-pod-install-150123/
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| installing gauges, stock or Autometer | 89dlx | 86-95 Trucks & 4Runners | 2 | 03-23-2007 10:09 PM |
| AUTOMETER Carbon Fiber gauges ... are they legible? | ManyMods | 95.5-2004 Tacomas & 96-2002 4Runners | 0 | 01-26-2004 05:15 PM |
| autometer gauges | kernel | 95.5-2004 Tacomas & 96-2002 4Runners | 1 | 10-19-2003 04:53 PM |
