where to buy power wire from battery to engine fuse
in the process of dealing with other problems i was lead to the power wire from the battery to the engine fuse in the engine bay fuse box. i was pulling the engine fuse out to try and check for bad connections when the end of that wire broke free from the plate its originally mounted to. wondering if anyone has bought one of these before from anywhere if toyota maybe has them?? any help would be great i just dont want to replace with another 20+ year old used one
I guess I am confused on what wire your talking about. Here is a diagram...
If it's the wire into the diagnosis box, then that should be part of the wiring harness.
