wet starters and solenoids
have any of you had problems with your starters or solenoids after they get wet, this is the third starter in a year i had to replace, i think rust and corrosion is the culprit ?, is it some way to stop it from getting wet like electric grease or something. thanks.
i open the starter solenoid and it looks like it's ben in the ocean for 7 years, i'll say corrosion is a understatement, water have been coming in a vent on the side and not going out
At least on the OEM (Denso) starters, there is a drain tube on the bottom side of the solenoid to let any water that does get in drain out. If yours has a drain tube, make sure it is not clogged and if no drain, consider getting a used Denso starter from a junkyard and swap that in.
Odin
09-26-2015 06:56 PM
