General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
Stupid Mistake...Now trouble shifting.
Old 06-09-2007, 12:38 PM
4runnersurf's Avatar
I have a 98 SR5 automatic. I unscrewed the shift knob, don't ask why just curious I guess. But now it has trouble shifting and when I put it in park I have to jiggle the shifter to take the keys out of the ignition. Whatcha think?
Old 06-09-2007, 02:33 PM
4Crawler's Avatar
Maybe the neutral start switch adjustment is off.
Old 06-09-2007, 02:49 PM
How would I fix that?
Old 06-10-2007, 04:20 PM
DrAnonymous's Avatar
I think you did the same thing I did once. The shifter release button is backwards. When you pull the shifter off you'll see a spring with a piece of plastic on the top of it. The plastic is what pushes against the shift release button when you go to change from park to drive. It can flip around backwards, but the shifter will still all go back together.
Take the shifter back off and make sure the plastic is facing 'forwards'.
Should look sorrta like this -
Code:
not this
Code:
HTH.
DrA>
voiddweller
10-02-2015 07:47 AM
PNW94Runner
09-29-2015 02:55 PM
Rickstwowheels
09-29-2015 02:23 PM
Matthew Perez
09-28-2015 05:43 PM
scheuvront1993
09-17-2015 06:17 PM
Quick Reply: Stupid Mistake...Now trouble shifting.
