Starter/ignition
Starter/ignition
Hey guys,
My '87 runner has been giving me some starting issues. Sometimes when I go to start it, it won't turn over right away. After several turns on the ignition (and a few choice words!) it will finally crank. This only happened every once in awhile but has since become more frequent. The other day when starting it, the starter kept cranking even after I turned the key off :think. I know these old trucks frequently have starter contact issues but I was wondering if anyone thinks this is more of a ignition issue or a starter one? Also when it does crank it's not slow like the starter brushes are seizing so I dunno? Any help would be greatly appreciated thanks!
Hey guys,
More like a Stuck Plunger
When problem occurs, try starting. Listen and feel. Starter relay should click and solenoid should also click.
Theoretically,
When solenoid plunger actuates it tries to do two things:
1) Close heavy contacts to send power to turn starter motor, and
2) Move clutch that will engage starter gear with flywheel.
If solenoid attempts to actuate but starter motor does not crank, contacts may not be closing because:
1) Not enough current to move plunger, OR
2) There is enough current but plunger is stuck
If (1) see wiring flaw explained on my thread/signature
Practically,
Your symptoms seem to point to stuck plunger.
a) takes several tries before it cranks, AND
b) "kept cranking even after I turned the key off"
Both combined suggests that there is mechanical restriction. Therefore, sometimes plunger does not move far enough to close contacts, but sometimes when it closes contacts it does not retract to open contacts after you have released the key.
Yeah that sounds about right because sometimes when it would crank but not start right away I would turn off the ignition and then go to start it again and it would grind like when you try to start a car that's already running. Do I just need a new starter then?
I haven't tried rebuilding a starter or solenoid but that can be done. If you have time, try to see what's causing plunger to get stuck. You would also see condition of contacts that probably need replacement as well. 4Crawler has info on his website.
Even after you have fixed the plunger problem, I still recommend you fix the wiring flaw I mentioned. Because it is a real problem. That is not the way to wire a relay to carry load current. If not fixed, it's only a matter of time before you fry your ignition switch which is harder to remove and replace than the work required to fix the flaw (on my sig).
RAD
RAD
similar problem on mine IMO, would start up.. drive down the road to get gas & then wouldn't start. then just waiting 3 minutes.. started right back up (sometimes on the 2nd crank). when I replaced the starter, the OEM one was in sorry shape and had a melted blob of something on the block side of the starter.
Starts like a champ now!
Still need to check for wiring flaw and correct it. Wiring flaw causes lower power to energize solenoid and actuate plunger. Good, starters whose solenoid plungers move smoothly allow that weak current to move plunger, masking the problem - like plastic surgery does on a hideous person. When plunger gets hard to move, problem is revealed, like it did in your trucks.
Scirocco16v, You got a first-gen 22RE as well?
Good write-up Rad. I wish I had seen that before I added a second relay to my truck. I never even thought about simply running a new power supply to the existing relay.
Hopefully its not the actual starter and just a power issue vs. a mechanical one but we will see. Good to hear starters are not too bad though! My dad (who just recently popped his Toyota cherry and got his hands on a '97 tacoma 3.4l!) and I will be diving into this tomorrow. Priority #1 will be replacing my brake calipers which are leaking around the pistons and after that is done we will dive into some starter diag. and then hopefully see the Ravens beat Denver!!
Staff
Followed RADs advice on the starter relay and what a difference. Taking the starter plunger out and giving it a good cleaning is a real easy job and would probably make just as much of a difference.
ok will do! and will prob replace contacts as well while in there!...Also flywheel should be fine considering just had a new tranny put in about 5,000 mile ago and everything was in good shape then (issue has only happened a handful of times; a few before and a few after it was replaced).
I just pulled my starter because it was grinding, probably every 3rd time starting. I completely disassembled it and lubed the idler gear and the bendix bearing. Haven't had the grinding since. I had already replaced the contacts and plunger and added an external solenoid a year ago.
I like your sig! I have in the past few years converted my family as well! Dad has an 02 4runner, brother has a 99 Taco and I'm on my 3rd 1st gen 4runner. Only problem now is I have to work on all of them! At least they don't need much. Just routine maintenance.
Don't remember the cost, I think $30 or so. It was easy, has to come out when you do the contacts anyway.
http://www.4crawler.com/4x4/CheapTri...OnlineOrdering
