Thread Tools | Search this Thread | Display Modes |
#1 (permalink) |
Serious electrical Problems
Ok, tonight while driving it was horrible because I had absolutely no dash light whats so ever. My brights indicator works, turn signals work, but no light on the actual dash. Plus the power to my radio will not work...Can anyone help me....
Also i'll be adding 4 radios, rock lights, siren flashers, on board air and a welder.... Do i need a a second batter....Can the 22r handle a bolt on welder....? |
| Sponsored Links |
#3 (permalink) | |
4 radios and a welder? You better do more than just add a welder.
First step would obviously be figure out what the hell is goin on with your wiring. Btw, have you tried just turning the dimmer switch? Or better yet, is it even there?
__________________
Need that hard to find part? Nix99 Used Toyota and Lexus parts! Quote:
#4 (permalink) |
In every forum there is one...look DeathCougar, I under that maybe you don't have the patience to deal with ppl who are asking questions, maybe you think they are lazy, maybe you think this or that...funny thing is...I came to the web site because I was tired of searching for dead end answers to my questions...I don't work my butt off at work, to blow it on something that aint gonna work for me...Now...maybe you deal with stupid ppl all day...I'm not one of them...My ing dash lights don't work..Read that again...just in case you didn't catch that....MY dash lights don't work! Ppl dont go to forums for other ppl to make them feel stupid even if they have a low technical amplitude level. Now...I was given this pick up...because I needed one...NOW I am left with trying to make the best out of it...For some odd reason the DASH lights DONT work...the radio in the truck was stolen and the previous owner said that since then the truck had a charging problem and the lights didn't work...He said that everything was reconnected, and fuses were replaced....and still dash light not working...Now....I just need to know what the common problem is when i comes to this...obviously its something happnes on these trucks...but no opens, no shorts, and fuses are Good....and Yes the damn dim switch is working...
4 radios- 1 Fire dept, 2 Hams,1 GRMS I do search and rescue and other things...I love this truck....I just need help getting it sweet. I just dont dive into crap.....that's a way you cost yourself crap loads of money.... |
#5 (permalink) | |
^wow.
My first question is, has anything recently changed before the problem? Has anything electrical been added/removed? Edit: question still stands, but if not, then i would just visually inspect all the wires under the dash, hood. Has this always done this or has it just started?
__________________
1990 4runner SR5, 3.0 with 254K, 5-speed, 4.56 gears, , Rancho 9000's, 33X12.50's trxus mt's, rear lock right, 4" lift with lc coils in rear Quote:
My build thread http://www.yotatech.com/f152/904_run...thread-158746/ Last edited by 904_runner : 08-19-2008 at 10:06 PM. |
#6 (permalink) |
dont get all pissed at coug... he is tryin to better figure out ur situation. also, he may have a fairy-like mohawk,
but he is one smart mother, you can learn a lot from him. i had the same prob with the lights, check the plug behind the dimmer knob, if its loose it will kill the lights until it is plugged in again. also, if you can read wiring diagrams, trace the hot line (red) and hook it up like that. if not, then hardwire the stereo to a switch, then an inline fuse, then to the battery. the switch being so you can turn off the stereo/radio and save your battery. hope it helps
__________________
The 22r series engines are made from the fires of hell, and will fight tooth and nail to not be sent back. 1988 Toyota P/U 4x4 22RE 258,000 miles on original motor pioneer CD deck 31x10.50x15 BFG A/T BAJA 100W lights on prerunner bumper KC Daylighters 100W rancho rs5000 MUD IS A VALID PAINT JOB! If not living life to the fullest, why live it? my trucks official buildup thread Last edited by ozziesironmanoffroad : 08-19-2008 at 10:12 PM. |
#7 (permalink) |
Yes, that does....I figured i would have to run a 12v to my radio...my speaker wires aren't even there....they were cut...so yeah...what about adding the welder to the engine and the dual batt system.
#8 (permalink) | |
Quote:
__________________
-Hayes |
#9 (permalink) | ||
Quote:
I offer a possible solution, and this is how you respond? Yikes! Like I said in my other post...you need to spend some time trying to figure out how to fix things or fab things yourself, instead of jumping on an online forum asking "this doesn't work, whats wrong?!" or "how hard is this?" There are a million possible things that can cause your dash lights and radio not to work. Try process of elmination; wiring, fuses, junctions, plugs, etc etc. You're right, there IS one in every forum ![]()
__________________
#10 (permalink) | |
Quote:
Dual batteries and an on-board welder are possible: - http://www.4crawler.com/4x4/CheapTri...atteries.shtml - http://www.4crawler.com/4x4/CheapTri...er/index.shtml
__________________
1985 Toyota 4Runner SR-5, 22REC engine, dual t-cases, 4.88 gears, dual ARBs, 33x10.50 BFGs. r.c.brown@ieee.org TruckEditor@tlca.org Project: 4Crawler 4Crawler OffRoad Gettin'Off 4WD Club |
#11 (permalink) |
DeathCougar, actually I am sorry. At any rate, I will find whats wrong....if the dash light are shot, do they just take any old bulb...or ?
#12 (permalink) |
they are labeled instrument bulbs
if you plan on running all of that stuff you might look into a GM ALT swap or get a belt driven generator from NORTHERN TOOL http://www.northerntool.com/webapp/w...6970_9040_9040 to run the welder and any other power tool you might need.
__________________
my rigs 89 4runner 1989 4runner v6 5 speed everything factory +4susplift running bfg 31s and a aux gas tank and more aux lights than needed 86 pickup 1986 stock pickup 22r 31.10 BFG ATs flatbed a sad day for the 4runner "One moment of patience may ward off great disaster. One moment of impatience may ruin a whole life." Last edited by CyMoN : 08-20-2008 at 08:12 PM. |
#13 (permalink) |
Ok...I will hack into this all friday or saturday night.
#14 (permalink) |
are your tail lights working properly?
if I remember correctly the tail lights run on the same circuit as the dash lights and radio. if I am right that means if the radio was yanked out and the wires where not put back in it could mess up the tail lights and dash lights.
__________________
my rigs 89 4runner 1989 4runner v6 5 speed everything factory +4susplift running bfg 31s and a aux gas tank and more aux lights than needed 86 pickup 1986 stock pickup 22r 31.10 BFG ATs flatbed a sad day for the 4runner "One moment of patience may ward off great disaster. One moment of impatience may ruin a whole life." |
#15 (permalink) | |
doesn't the factory radio also dim with the dash lights? if so, maybe when the radio was axed the wiring was shorted (light and +12v/memory) and fried the dimmer? and since all the dash lights ground through the dimmer, no worky.
__________________
Quote:
#16 (permalink) |
We have all felt frustration like that darkangel.
We are here to help you out dude. You got the wiring diagrams or need help finding them?
__________________
99 4Runner SR5 4wd 3.4/5 spd Factory Rear Locker/Rear Diff Breather Extension LT265/75/16 Nitto Terra Gs- AR767s Old Man Emu springs- 881 fronts/891 rears Old Man Emu shocks- N91s fronts/ N86 rears All Pro Off Road sliders/ARB "Taco" bumper Redline Tuning hood struts -prop rod now useless! TrueFlow Air Filter fed by airbox deckplate mod Rear wing custom painted in body color (white056) |
#17 (permalink) |
I do not have the wiring diagrams....and here recently another problem arose out of this mess....My battery just all of sudden started die'n. Brand new alt, and so I am very eager to nip this problem in the bud real soon...
#18 (permalink) |
Check grounds and all connections.
You could bypass the dimmer and just have it all a full 12V. Thats what I've done on my runner.
__________________
1996 4Runner. Revos, tundra brakes, 5" deckplate, ISR, inverter, addco sway bars, marlin 1200lb clutch. More to come! |
#19 (permalink) |
If all this is still not working try attaching speakers, I know that some aftermarket stereos won't power-up until speakers are attached.
__________________
Luke I decided that I needed a new hobby on a Wednesday and that off-roading was going to be it. By Friday I found myself the proud 3rd owner of a: '92 4Runner, 3.0L V6 4x4, 5 speed, 2” body lift, 2.5” suspension lift (OME HD coils in back and BJ spacers in front), Off-road pan hard drop bracket, off-road idler arm gusset, off-road IFS front truss brace (all Downey), all stacked on 33"s. Now I Lurk & Learn thanks to the wealth of info from you all here on YotaTech. |
