rock crawler electrical ?
Hey, had a few things and i thought this was the place to find the answers. First, my name is Mike, i have an 87 pickup and i have done a few mods. I went propane, sas, fj80 brakes, chevy rear springs, 4.7 t case gears, 37"MTRs, hi steer, full exo blah blah. With the propane kit i eliminated alot of crap ie EGR, man. fuel pump, tons of electrical. What im wondering about is the electrical. I have to have power to the cylanoid to the propane, and i have an elec pusher fan, and a few lights. I would like to clean out EVERYTHING that isnt necessary. Does anyone know where to find some good resourses on this?
Pirate4x4 but be sure to search the topic first before just posting there because people can be really obnoxious if ya know what I mean. Search more and Im sure youll find the answere
Get a simple aftermarket wiring harness. Summit, Ron Francis, Painless, etc... They make good, simple harness' to suit your needs. They even make the custom and race switch panels in a weatherproof version for rigs like yours.
I doubt anyone would be able to make you a plug-n-play harness, since your rig is so custom. Surely you'll need to design most of the harness yourself.
I've pulled a bunch of harnesses into dune-buggies and sand rails from Scratch. The attached schematic is a basic harness that I colored, that is available at any VW Parts house or supplier for around $30. The fuse-block supplied sucks and should be upgraded to Blade-Style fuses. It is a good starting point for any basic rig and contains everything needed to be street legal. I usually add terminal blocks for things like ignition, ground, etc. Because it makes it much easier to add accessories and customize.
FS[PacNorWest]: 1993 4 Runner, V6, 4wd, Auto,
AkitaDog
09-03-2015 09:01 PM
