General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
Non-working fuel gauge
Old 01-10-2010, 09:18 AM
lctmjw's Avatar
I just bought (sight unseen) a 91 Landcruiser. Pretty solid overall with 135k, but it wasn't well taken care of and needs some tlc. My biggest concern at the moment is the fuel gauge isn't working, though fortunately the low level light does. Am I correct to assume that the the float and sending unit are functioning, since the low level light works? Any advice greatly appreciated, I know very little about these trucks.
Old 01-10-2010, 12:24 PM
myyota's Avatar
If the sending unit and low fuel sensor is set up like my 86 4Runner, Then the fuel gauge sending unit and low fuel light are mounted together but are two seperate units, so the fuel gauge sending unit can go bad and not work at all, but the low fuel light will still operate normally. The sending unit on my 4Runner is going bad also and because both of these units are together in one unit i bet its going to be an expensive part to replace.
Old 01-10-2010, 12:29 PM
lctmjw's Avatar
Thanks for the quick reply. I imagine the senders are in the tank.. Wonder if I can get to them via the cargo area? Guess it's time to buy another TSRM.
Old 01-10-2010, 12:44 PM
myyota's Avatar
I don`t know anything about Landcruisers, but on my 4Runner there is an access panel under the rear seat for the fuel pump, but to get to the fuel gauge sending unit you have to remove the gas tank to get to it.
Old 01-10-2010, 12:49 PM
lctmjw's Avatar
Wow, that sucks. I'm kind of surprised the sending units aren't as accessible as the pump. There's no chance I'm removing the fuel tank before spring comes, may have to break down and pay someone to do this for me. Not cool. Thanks for the quick info.
Old 03-13-2011, 11:59 AM
otarunner's Avatar
is there by chance a relay that is faulting between gas tank and the other end of the gas gauge my gauge also dont work took a working sending unit didnt make a difference and it is a 1986 4runner
Old 03-17-2011, 03:01 AM
Hadmatt54's Avatar
My 86 pickup the fuel gauge stopped working, so I took the sending unit out of the tank, tore it apart replaced the top made new connections on the variable resistor and when I was finished I checked all the ohm readings as per the FSM and it was spot on. Put it back in the tank and it wouldn't work. So I ordered a new one from Toyota put it in the tank and nothing, so I said to heck with it, filled up my truck and drove it. On the first trip into town it started working again, so don't be discouraged if you repair it and the gauge doesn't work right away. The moral of this story is I bought a sending unit that I really didn't need, I may put the repaired one back in and keep the other for a spare. There is mo relayin this circuit on an 86 and I dopubt if there is one on the landcruiser...the current draw is so low it would be a waste of a relay.
Old 04-27-2011, 05:38 AM
Mr.Utah's Avatar
How much are the sending units?
Old 05-04-2011, 01:38 PM
Hadmatt54's Avatar
Part # 83320-39695 Sending unit 86-88 pick-up 4wd sr5 w/o turbo
$137.69 from Champion Toyota Houston Texas.
Old 05-04-2011, 04:07 PM
Mr.Utah's Avatar
Thanks, they are asking $181 here in SLC.
Old 07-23-2011, 07:21 AM
yotarover's Avatar
this one isn't as old as some others. will the sending unit from a late model 88 work pre(89)
Old 07-23-2011, 10:51 AM
Hadmatt54's Avatar
yotarover: this one isn't as old as some others. will the sending unit from a late model 88 work pre(89)
Not exactly sure what you are asking...would you care to give some detail?
Old 07-23-2011, 04:48 PM
celica_gtx's Avatar
Im havin the same problem on my turbo 87 runner.. I bought the truck w a non workin the dash was flashin on the meter and the lamp on.. I replaced the float and still doesn't work. Gauge stoped flashing but not reading. I saw resistance in the float and 5v.. where do I go from here? Btw it does have the digital cluster.
Old 07-23-2011, 04:53 PM
celica_gtx's Avatar
And it has fuel in it.. appx 5 gals..it should atleast bring up a bar..
Old 07-24-2011, 07:38 AM
Mr.Utah's Avatar
I went the rounds myself with the fuel gauge problems, spent the money and put in a new one, problem solved. My old one would get to a 1/4 tank then drop to empty. Still have it if you want the old one?
Old 07-24-2011, 07:55 AM
celica_gtx's Avatar
Ima try gasin it up more than to see it that's about the same problem w me.. I had purchesed a used one from yoda jims.. im track the wires and make sure everything is good.. thanks tho ill let you know
Old 08-29-2011, 08:31 AM
FattMaanLittleTruck's Avatar
i just picked up a fuel sending unit for $14 from the junkyard.
glad I didn't pay $100+ at the stealership.
Old 08-29-2011, 06:39 PM
ashtonbrn's Avatar
I've got the same problem on my 88 4Runner. Fuel gauge doesn't work so I go off miles and the low fuel light. Had to put that one off to fix other things.
gary4runner
09-24-2015 12:53 AM
shisha1999
09-21-2015 08:22 PM
RobotMoose
Diesel Swaps
08-02-2015 11:00 PM
Tyler Cunningham
07-11-2015 10:18 AM
Poncho0206
07-10-2015 06:21 PM
Quick Reply: Non-working fuel gauge
