Need info on O2 wiring '96 4R(someone stole my cat...)
So someone hacked out my cat, taking the two O2 sensors with it... I've had a replacement cat put back in along with bungs and O2 sensors, but the harness for the rear sensor is trashed. Looked for a replacement connector in a few wrecking yards, but no luck, so I'm going to make my own connector using butt connectors...
Havent found a wiring guide that tells which wire go to which corner of the connector, so I need some help on that info. If anyone can take a look at the wire colors on the connector (truck side, not O2 sensor side) I'd greatly appreciate it.
Thanks!
Thanks!
stockwell45
354
11-15-2014 02:29 PM
midiwall
35
01-04-2013 10:40 AM
Myron
09-08-2009 10:41 AM
