Fogs from Burtman Industries
Just installed them today. I know some people around here were looking for fogs that fit in the factory location for 3rd gen 4runners. These are excellent quality, and very easy to install. They do come with remote controls, but I decided to just wire them up to the stock wiring and use a LED switch inside to control them. The most important part is to aim them correctly, which takes some time to get it perfectly right, I will probably tweak the aim on these a little tomorrow. Anyways, what's a thread without pics, right?
Heres how they are aimed right now, and look at the difference between the headlight and fog light bulb colors! I emailed Jason, and he said they are just normal bulbs. I already bought some Nokyo yellow fog light bulbs to replace those though, and I will eventually purchase some bright white bulbs for the headlights.
and Jason was very helpful with any questions I had, I will definitely buy from him again! Thanks!
How much were the lights from Burtman as opposed to the Hella DE Micros that Performance Products sells. Did they install into the wiring that is already there or did you have to modify? Thanks in advance.
Jason's lights were $160. They were very easy to install, the way I installed them, there were some wires that had to be spliced. These lights came with a control box, so really you do not have to rewire anything, but I wanted them to act stock, so I just spliced into the stock fog wiring. I bought some quick disconnects from www.waytekwire.com in case the bumper ever has to be removed. If you want more details, let me know and I can post more pictures, and I guess I could do a full write-up if there is enough interest.
justdifferentials
14
06-11-2017 08:36 PM
TStango
12
11-20-2004 06:22 AM
UKMyers
16
11-18-2002 01:04 PM
Lurch
13
11-12-2002 01:37 PM
