YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > General Electrical & Lighting Related Topics
Home Photo Gallery Register Search Today's Posts Mark Forums Read Tread Lightly Wiki
Thread Tools Search this Thread Display Modes
Old 08-09-2008, 07:57 AM   #1 (permalink)
frodin1's Avatar
Dimmer/ Head unit question.
Obviously, there's issues hooking up the dimmer feature on new head units, and Toyota's, since that's all I found searching. I have a ground wire and a hot dimmer wire on the 3rd gen. harness, and only 1 lead on the new HU. Should I just leave this thing disconnected to avoid any issues? I read these things are wired bass ackwards on our rigs. All I have is the diagram they gave me with the new Head unit. No actual schematic to speak of? Advice?
__________________
Pioneer HU, Audiobahn 10.100watt Sub, Sirius, Cobra NWWXST CB W/ K40, Wolo Air horn, K&N FIPK,Tokico Trekmasters,Tundra TRDs, Revtec spacers w/extended studs,Energy bushings on steering rack /front swaybar,SS front diff. drop kit w/skid plate mod,OME 890 Rears with OEM LC Tokicos,Ebrake ext. bracket, BFG AT/KO's, ProComp 1078 Alloys, Magnaflow SS muffler, Hayden 1678 Tranny Cooler, 85watt Amber fogs, 7 Way R/V plugin.
frodin1 is offline
Sponsored Links
To remove this ad, register today!
Old 08-09-2008, 08:37 AM   #2 (permalink)
Elton's Avatar
Send a message via AIM to Elton Send a message via MSN to Elton
i just used a harness that plugs into the factory wiring been working find
__________________
My Truck 98 4runner SR5 3.4L 5spd 4x4 E-Locker Mods
Mom 07 Tundra d-cab limited 5.7L 4x4 auto
mom 92 pickup SR5 X-cab 3.0L 5spd 4x4
Papa 89 Pickup SR5 X-cab 4x4 3.0L 5spd/98 4runner SR5 4x4 auto 3.4L
R.I.P 91 4runner SR5 4x4 3.0L 5spd Totaled 5/13/06 My Wreck
Elton is offline
Old 08-09-2008, 09:14 AM   #3 (permalink)
frodin1's Avatar
That's what I have. But that harness has 2 wires for the dimmer and the Pioneer only has 1 comming out?
__________________
frodin1 is offline
Old 08-09-2008, 09:26 AM   #4 (permalink)
4Crawler's Avatar
The main issue you run into is the stock Toyota dimming lights are set up with a floating ground. That is all the lights are powered from a common source then the "grounds" are all tied together and then run through the dimmer to finally hit ground. If you connect in a device that is grounded to the chassis (common with 1-wire lighting setups) then you find the device runs in parallel to the dimming lights and that makes it dim opposite to the rest of the lights. But if the dimmer input is just a voltage level sense , then it is probably OK to connect the hot dimmer wire from the vehicle to the dimmer input of the radio. Or just tie it to a 12 volt power line to keep it constantly dimmed.
__________________
1985 Toyota 4Runner SR-5, 22REC engine, dual t-cases, 4.88 gears, dual ARBs, 33x10.50 BFGs.
r.c.brown@ieee.org
TruckEditor@tlca.org
Project: 4Crawler
4Crawler OffRoad
Gettin'Off 4WD Club
4Crawler is offline
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
should be an easy dimmer question Brenjen General Electrical & Lighting Related Topics 5 06-19-2008 07:06 AM
Dimmer question Ehinfinity Vehicle Audio & Home Entertainment 5 04-10-2005 12:52 AM
Head Unit Install Help/Question orangeman_85 95.5-2004 Tacomas & 96-2002 4Runners 10 01-07-2004 03:22 PM
Help with head unit fooddude 95.5-2004 Tacomas & 96-2002 4Runners 16 11-09-2003 09:06 PM
Head Unit question C2damuthafuqinLO 95.5-2004 Tacomas & 96-2002 4Runners 3 08-26-2002 07:40 AM
Powered by vBulletin® Version 3.6.4
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
2002-2008 Yotatech.com
